Are 96-98 civic coupes same as 99-00 coupes?
Old Apr 7, 2006 | 04:34 PM
superg6819's Avatar
Default Are 96-98 civic coupes same as 99-00 coupes?
So i crashed my 00 si and i am gonna sell the shell. I am taking off as many parts as i can and gonna find a 96-98 coupe and swap as many parts of as i can. First thing, will my b16a fit into a 96-98 if i use the b16a motor mounts? Other things like my exhaust, skunk 2 camber kit and coil overs and shocks i am pretty sure they will fit right up. i know the front ends are a little different (grill and headlights are smaller) Is there anything that won't fit at all? thanks!
Old Apr 7, 2006 | 04:48 PM
Voyage34's Avatar
Default Re: Are 96-98 civic coupes same as 99-00 coupes? (superg6819)
other than cosmetic stuff like the front end, taillights and radio/ac cluster i dont know of any differences. afaik mechanically they are the same
Old Apr 7, 2006 | 05:08 PM
Vero's Avatar
Default Re: Are 96-98 civic coupes same as 99-00 coupes? (Voyage34)
everything is the same except for:
96-98 are OBD2a
99-00 are OBD2b
Different front ends, including headlights and fogs
Different tail lights
Different cup holder
Different climate control console (to be more technical, the whiole bezel, heater core, blower and vent tubes)
Now the 99-00 Si also had read Disc Brakes and a Rear Sway, which no other coupe had.
Otherwise everything is interchangable on the cars, all your 99-00 Si stuff will bolt right on to an 99-00 Coupe.
Old Apr 7, 2006 | 05:09 PM
superg6819's Avatar
yeah thats what i was thinkin
Old Apr 7, 2006 | 05:14 PM
.Ry's Avatar
.Ry
Yes, all of your suspension, exhaust will bolt up. Swapping your B16A2 shouldnt be that bad either. Im not sure exactly what mounts you will need, but im guessing you will use the ones from your SI.
Old Apr 7, 2006 | 05:32 PM
bmoua's Avatar
it will all bolt up...and plz get a 99-00 ex bro...haha...
Old Apr 7, 2006 | 05:44 PM
b18ccivics's Avatar
the wiring is different, so use the 98 harness with the 98 car with the b16 from the 99 and use an obd2a to an obd2b jumper harness and the 99 si ecu
The Collin
May 8, 2009 12:33 AM
Midori Green
Sep 1, 2007 12:04 AM
ghettochild
Jan 28, 2007 06:15 PM
EKbeast
Aug 13, 2006 07:01 PM
turbocoupe
13
Jan 13, 2005 03:40 PM
