rere
a rephrasing with punctuation and some normal syntax would be nice, but i got if after a couple tries.
you didn't say what the new motor you are putting in is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">th car had and ls a while ago took it out and sold it then now puttin gthis new motor in just finished building it and now it wont start it has ls injectors </TD></TR></TABLE>
The car originally had a LS motor in the car. I took it out and sold it. I swapped in this new motor and now it wont start. I used the LS injectors.
I tried my best to translate it in english.. although he doesnt give that much info.... were supposed to magically know whats wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exsinnovation »</TD></TR><TR><TD CLASS="quote">
The car originally had a LS motor in the car. I took it out and sold it. Now i out in this new motor and now it wont start. I used the original LS injectors</TD></TR></TABLE>
Wow, I am still speechless even after the translation.
If you eatsleepjdmef learn who to spellandpuncuateusdmlanguage
A bit more info? If you want us to help and spend our time typing, help us first - spend some of your time typing. Don't be shy, its not hard.
My guess is he ran the old LS obd0 with the obd0 injectors, and the new LS is running obd1 injectors. If you are using the newer (saturated) injectors, you must remove the resistor box. Search how to remove it, and how to test if your injectors are saturated or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">A bit more info? </TD></TR></TABLE>
sorry on my typing guys, i was replying to another user and did it wrong. i new and i dont know what to do! sorry. my problems is i just put a 1990 ls into my 90 si hatch. the car had an ls prior to this one and it ran fine. now my car cranks but wont fire. i have spark. fuel pump kicks on, but only getting fuel to the top of the injectors(no smell on spark plugs...) tried 2 ecus 2 resistor boxes, and im stumped can you help me?
