getting oil on my sparkplugs
Old Apr 7, 2006 | 03:01 PM
krz6jdm's Avatar
Default getting oil on my sparkplugs
how do i fix this my cousin said its from a broken seal but which seal? and how come only 2 are wet and the others are dry?
Old Apr 7, 2006 | 03:07 PM
saikouEF8's Avatar
Default Re: getting oil on my sparkplugs (krz6jdm)
this happend on my old crx cuz one of my head studs was stripped.....
heres what to do...
take off ur valve cover and wipe the excess oil from those gaskets. also wipe the edges where the valve cover meets the head. then either get a new set of valve cover gaskets or use the exsisting ones if ONLY IF U ARE SURE they arent worn broke or briddle....HOWEVER ***its always better to use new gaskets when doing stuff like this*** . also put some honda bond on the edges around the cam gear. also make sure the valve cover is properly torqued down. thats it
Old Apr 7, 2006 | 05:58 PM
Jonknee's Avatar
Is it on the thread of the spark plugs? Where exactly?
Old Apr 7, 2006 | 06:15 PM
krz6jdm's Avatar
Default Re: getting oil on my sparkplugs (efnewb91)
awrite ill chk it awt tnx.
Old Apr 7, 2006 | 06:36 PM
ludesrv's Avatar
Change the valve cover GROMMETS. They usually come with a kit for a new valve cover gasket aswell. Mine where so bad it flooded the spark plug and wouldn't spark anymore...the engine died. I replaced them all and it started right up...with new plugs aswell.
garykf16
Apr 13, 2009 04:09 PM
standbackimapro
Apr 29, 2006 05:38 PM
Hey Whats Up
May 5, 2005 04:46 PM
blackflag188
Nov 9, 2004 04:54 PM
CalvitoSol
Jul 8, 2002 12:03 AM
