foglight bulb replacement
Old Apr 7, 2006 | 02:54 PM
egcivicb16's Avatar
Default foglight bulb replacement
i went to replace my foglight bulbs today and when i was done they wont light up, i checked with a volt tester and there is power all the way to the bulb but no light up.
Old Apr 7, 2006 | 03:17 PM
egcivicb16's Avatar
any ideas??
Old Apr 7, 2006 | 03:31 PM
bmoua's Avatar
my bulbs on mine went out too...i still have to replace them but hopefully i dont come up with the same problem as you bro...
Old Apr 8, 2006 | 04:34 PM
egcivicb16's Avatar
bump, any ideas??
Old Apr 18, 2006 | 01:08 PM
nurvcom..'s Avatar
Default Re: (egcivicb16)
i had a problem with my fog light and come to find out the fog switch was bad!! so you mite check the switch!!!
Old Feb 11, 2007 | 09:43 AM
93civicexthug's Avatar
Default Re: (nurvcom)
do u have to take the whole bumper off again to replace the bulb? and i would check the switch, when i first hooked them up they wouldn't work until i played with switch a little
Old Feb 11, 2007 | 10:12 AM
ITLNstallion818's Avatar
Default Re: (93civicexthug)
as stupid as it sounds, check the harness, specifically the clip that connects the harness to the actual foglight... it might be loose-- mine comes loose every once in awhile
Old Feb 11, 2007 | 10:15 AM
Eran's Avatar
HT White Ops
Check your ground inside the foglight housing.
dgdarien
12
Jan 6, 2016 05:00 PM
papi123
Honda Civic (2001 - 2005)
Aug 19, 2014 09:11 AM
6doorsentra
Apr 9, 2006 07:41 PM
krnboixshawn
Feb 4, 2003 10:21 AM
