What Timing Belt to Use and AC bracket, 97 JDM B16A in a 96 Civic EX
Old Apr 7, 2006 | 02:24 PM
eargsm1's Avatar
Default What Timing Belt to Use and AC bracket, 97 JDM B16A in a 96 Civic EX
I just put my B16A in yesterday and need to get an AC bracket to fit. I also need to get the timing belt for it. Do I get a belt for a US 99 SI? One honda dealer said that they have seen issues with those because of differences in teeth with the JDM motor. I will probably just get the number off the belt tomorrow and try looking it up with that. Anyone know the correct belt to use or what bracket for the AC?
I also would like to thank http://www.hmotorsonline.com for the engine. I will only buy motors from them. I got everything in perfect condition, even sent brand new axles.
Old Apr 7, 2006 | 02:26 PM
Spade's Avatar
Default Re: What Timing Belt to Use and AC bracket, 97 JDM B16A in a 96 Civic EX (eargsm1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eargsm1 &raquo;</TD></TR><TR><TD CLASS="quote">I just put my B16A in yesterday and need to get an AC bracket to fit. I also need to get the timing belt for it. Do I get a belt for a US 99 SI? </TD></TR></TABLE>
Yes, you can use the 99SI belts.
Old Apr 7, 2006 | 02:30 PM
eargsm1's Avatar
Is there any difference in the belt on the JDM, I don't see why it would be different. It is the same motor! Do you know what Bracket to use to keep the AC?
Old Apr 7, 2006 | 04:07 PM
93Civac's Avatar
If your using the d seires compressor then get the ac bracket for a 97 CRV, its about $70-$80 from honda ( cheaper than del sol bracket) and it will directly bolt up to your b16 and all 4 bolts on the compressor will bolt up. I used this on my b16 swap.
Old Apr 8, 2006 | 04:50 AM
eargsm1's Avatar
Default Re: (93Civac)
Thanks for the help!! Hopefully I will have my car on the road again on sunday! Will post pics later.
reydio
Sep 26, 2006 10:06 AM
90civichbsi
Aug 10, 2006 11:45 AM
CTL
May 13, 2004 09:35 PM
BigBank420
Mar 12, 2002 04:48 AM
