rev limiter??
Old Apr 7, 2006 | 01:37 PM
just rave's Avatar
Default rev limiter??
do 91 STDs have rev limiters?
i cant seem to find mine.
thanks
Old Apr 7, 2006 | 01:48 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: rev limiter?? (just rave)
keep trying you'll find it
Old Apr 7, 2006 | 01:49 PM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by just rave &raquo;</TD></TR><TR><TD CLASS="quote">do 91 STDs have rev limiters?
thanks</TD></TR></TABLE>
just leave it in 1st and try and 60
Old Apr 7, 2006 | 01:52 PM
crxnj's Avatar
I think its like 5000revs,,or somewhere around there..
Old Apr 7, 2006 | 02:05 PM
djphonics's Avatar
Default Re: rev limiter?? (Mr.speaker)
lol you can't find it??? just wrap the sucker out in 1st gear. it will let you know by going weeeweeweeeweeeweee
Old Apr 7, 2006 | 02:47 PM
si0385.'s Avatar
it shouldint be that high on an std
Old Apr 7, 2006 | 04:18 PM
efnfast1's Avatar
Default Re: (si0385.)
just floor it you'll find it eventually.......lol
Old Apr 7, 2006 | 04:34 PM
orangeracer's Avatar
is it on the motor or in the ecu the rev limiter an is stds a deses wat does that mean i think my girl friend had that jk
Old Apr 7, 2006 | 04:46 PM
firebane's Avatar
6,000rpm.. haven't found mine :D
ludesrv's Avatar
Default Re: (orangeracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangeracer &raquo;</TD></TR><TR><TD CLASS="quote">is it on the motor or in the ecu the rev limiter an is stds a deses wat does that mean i think my girl friend had that jk</TD></TR></TABLE>
What?
Ok, here's my reply to that. Rev limiter is a electronic control that cuts the engine from revving to failure. It's definitly not a bolt on haha.
STD is for for Standard, or basic if you wish, the base model Civic/CRX.
Old Apr 7, 2006 | 06:09 PM
just rave's Avatar
Default Re: (BIG DIXX HOLLA)
yeah. i dont know.
i mean it feels like im revving the **** out of it, but it just keeps going.
its kinda scary without a tach. hah.
Old Apr 7, 2006 | 06:12 PM
si0385.'s Avatar
what
Old Apr 7, 2006 | 06:22 PM
just rave's Avatar
WOW.
how old are you?
Old Apr 7, 2006 | 06:23 PM
sorry i got it stds standerd wow wasnt thinkin thanks wats the best way to bypass or get rid of rev an speed limiter
Old Apr 7, 2006 | 06:24 PM
si0385.'s Avatar
get a socketed ecu and have someone burn you a chip for it
Old Apr 7, 2006 | 06:26 PM
socketed ar some welded in ?
Old Apr 7, 2006 | 06:34 PM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangeracer &raquo;</TD></TR><TR><TD CLASS="quote">socketed ar some welded in ?</TD></TR></TABLE>
They soder in a socket for racing chips...
Too be honest, you don't need it unless you have a better engine with better internals. I refuse to chip an ECU until some internals are replaced by better ones. Like springs/retainers so the valve can actually bounce back at a higher RPM. If your springs are weak, your piston will come up faster then the valve can retrack, cause the valve to hit the piston, ruining your motor. We did that about 2 years ago to a SOHC ZC. We chipped it to 10000rpm rev limiter. We took it to 8400rpm regularly, it didn't like it, but it took it. One day we decided to blow the motor. So we held it at 9000rpm for a bit and nothing happened. Then we punched it to beyond 9400 when all hell broke loose. We threw a rod right thru the block. Infact, the rod brought the piston out with it, so the whole was the size of my hand...oh memories.
dohc_profile's Avatar
rev limiter? same thing has fuel cut right? my engine just revs to about 7500 (d15b2) thats as high as hte engine can make it. its just not capable of anyhting higher
Old Apr 7, 2006 | 06:38 PM
i would like to get a chip for my d16a6 but i mean i only want it for that extra lil bit an to take off the speed limit an is it worth it?
Old Apr 7, 2006 | 06:40 PM
si0385.'s Avatar
Default Re: (dseries_ef)
my ecu: the red rectangle on the right side is where the socket is the black thing is the chip the white circled thing is a dada link port... this is the type of ecu i was talking about and while ludesrv makes a good point i picked up the ecu dirt cheap and the chip was only $30 from john vega at phearable.net so it actualy wound up being cheaper for me than just buying a p08 ecu plus its better in the long run cuz im gona be boostin soon
Old Apr 7, 2006 | 06:50 PM
ok so u replace the far right one an tat one is the rev an speed
Old Apr 7, 2006 | 06:54 PM
aXhatch's Avatar
I didnt want to post another topic about this, so I hope I can jack the thread for jsut a second or a few replies.
When cold, my D15B7 w/obd0 si ecu, only runs to 5k rpms. but after warmed up (10seconds later due to ehadgasket blown) it will rev then to 6500, stock rev limit.
Is that prevailent on ALL motors, or is it just because its a frankenstein motor/ecu and all that.?
Old Apr 7, 2006 | 07:00 PM
si0385.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangeracer &raquo;</TD></TR><TR><TD CLASS="quote">ok so u replace the far right one an tat one is the rev an speed</TD></TR></TABLE>
you need to have a socket soldered in there but if you are good with an iron you can put it it you can order the kit from phearable.net and the chip from phearable.net and if you do it its actualy very cheap... but yes that controls the revlimiter and top speed i set my rev limit at 8k just incase i miss a gear i wont ruin the motor, and the vtec x over at 5300 but i only take it up to about 7-7200 (what there rated for stock) but i dont have a top speed limiter either
plus the fuel and timing maps are a little different than a stock p08 because of the intake and pretty much open exhaust i run on a daily basis
aXhatch im not sure about your problem how would you know it only revs to 5k less than 10 secons after it starts? i hope your not just turing it on and reving it that high right away???
KDvtec5757
Jul 1, 2008 07:30 AM
rmvti
Nov 29, 2004 03:17 PM
Jockobo
Oct 1, 2004 10:14 PM
