Car won't Crank ---Please Read---
Old Apr 7, 2006 | 01:16 PM
QUICKERSILV3R's Avatar
Default Car won't Crank ---Please Read---
Obd II Gsr motor with Obd I Ecu...
93 Civic Ex
Symptoms, Car will not crank battery is charged and fine, tried replacing the starter still the same results.. the motor itself is fine because the car starts when push started...checked all the fuses. .. is there anything else to check I'm really in ah jam here with this being my only transportation
any input, opinions, etc. etc. would be greatly appreciated
Old Apr 7, 2006 | 01:23 PM
IHateJDM's Avatar
Default Re: Car won't Crank ---Please Read--- (QUICKERSILV3R)
what does it do when you try to start it? does it turn over, just hear clicking, nothing, etc? can you hear your fuel pump prime? If it turns over, can you smell gas by the fuel rail after trying to start it?
Old Apr 7, 2006 | 01:29 PM
Default Re: Car won't Crank ---Please Read--- (IHateJDM)
doen't crank or turn over at all. It does make a click if your standing right next to the battery, its a very slight click not loud like when your batteries dead, I just read that it could be the clutch signal that could have gone..
Old Apr 7, 2006 | 01:32 PM
IHateJDM's Avatar
how do you know your battery is good? try it in another car, or test it at autozone? sometimes it'll have enough power to run the interior lights and radio, but not enough to crank the car.
for the clutch switch, look under the dash by the top of the clutch pedal, and you'll see a switch with 2 wires going to it. Jump those wires together, and you bypass that switch.
Old Apr 7, 2006 | 08:59 PM
thanks for the input bro ...try this stuff tonight!!
micah_m
Aug 19, 2016 10:50 AM
DIZSTRICTxB3A5T
Mar 11, 2011 12:41 PM
guymosiris
Mar 17, 2010 05:03 PM
deftones0817
Jul 14, 2005 08:17 AM
