ZC Distributer wiring help needed.
Old Apr 7, 2006 | 12:23 PM
AudioXtremes's Avatar
Default ZC Distributer wiring help needed.
I was just about to cut the plug off my ZC distributer when I noticed that the colors were different on both the original HF plug and the zc plug according to this picture I made a similar one with my wiring colors on it. Please let me know what you think I should do.
Old Apr 7, 2006 | 03:14 PM
civicjdmb16a's Avatar
Default Re: ZC Distributer wiring help needed. (AudioXtremes)
do any of the colors match from clip to the dist? If not tell me what colors you have to deal with here
Old Apr 7, 2006 | 04:04 PM
efnfast1's Avatar
seems to me that you have already fig. it out and u dont know it yet all the colors are there.....
Old Apr 10, 2006 | 04:26 AM
Default Re: ZC Distributer wiring help needed. (efnfast1)
None of my zc distibuter plug wires match the image from zcr.
Old Apr 10, 2006 | 05:24 PM
zccr-xsi's Avatar
wow i used that same pin-out for my wiring it they matched to perfect?u sure u got zc dizzy?post a pic of it and the plugs.
DONT CUT IT!!CAREFULLY TAKE THE WIRES OUT OF THE CLIP!
Old Apr 10, 2006 | 05:58 PM
mntuner2's Avatar
They are probably sooo faded that it looks white or pink but it is orange. A manual from the parts you have will always help.
*edit*
You can depin the connectors, just don't pull them out at the same time(i.e. only depin crankshaft position sensor wires, theres three snesors and the output from the ignitor on 88-91 MPFI EFs and many others. You can always open the distributor and look at where the wires go, explained in the Honda Serive Manual.
Good Luck!
Old Apr 10, 2006 | 06:43 PM
zccr-xsi's Avatar
Default Re: ZC Distributer wiring help needed. (mntuner2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mntuner2 &raquo;</TD></TR><TR><TD CLASS="quote">
Good Luck!</TD></TR></TABLE>
Old Apr 11, 2006 | 01:26 AM
Default Re: ZC Distributer wiring help needed. (vteckillenzc)
Thanks guys. I just matched number positions to number positions and it worked. But the colors in no way match. Weird huh.
zdelure
20
Jan 23, 2012 03:24 PM
StupidSlowRSX
Apr 7, 2004 07:41 PM
Sherm
Apr 18, 2003 06:45 PM
drjondurst
Mar 23, 2003 06:05 PM
