anyone here actually have those jdm style CF hoods for usdm civic/crx's?
Old Apr 7, 2006 | 11:41 AM
StickyGreen's Avatar
Default anyone here actually have those jdm style CF hoods for usdm civic/crx's?
Anyone have this "hump" reversed hood?
If you do, would you mind posting a pic of it. I've searched but no one has actually posted a pic of it.
I might have to get one because of hood clearance issues..
Thanks a lot.
-sticky
Old Apr 7, 2006 | 11:56 AM
92 si hatch's Avatar
Default Re: anyone here actually have those jdm style CF hoods for usdm civic/crx's? (StickyGreen)
bump. I'd like to see the same thing. I'm gonna do a b16 swap and not sure that the stock hood will have the amount of clearance that I will need. I'm getting a carbonfiber hood but want to make sure that I do it wright the first time.
Old Apr 7, 2006 | 12:17 PM
ludesrv's Avatar
A stock hood will cover a B series. HASport, and most mount kit companies realise that not everyone has a JDM front end, so they make sure the stock hood will fit.
Your looking for the Civic/CRX SIR hood, don't say the reverse hump...
Old Apr 7, 2006 | 02:32 PM
em Dot's Avatar
POOPCheeks
in sport compact car a few monthes back, hasport had a usdm crx si with a jdm hood. you can tell the placement wasnt perfect. let me see if i can find a pic of it....
Old Apr 7, 2006 | 02:38 PM
tommycrx's Avatar
Default Re: anyone here actually have those jdm style CF hoods for usdm civic/crx's? (em Dot)
From Fiber images:
Sorry it kind sucks, but it's much better than their customer service is.
Old Apr 7, 2006 | 02:40 PM
88 rex's Avatar
Not the greatest pic but you get the idea. Fiberimages hood.
The underneath of the hood.
Old Apr 7, 2006 | 02:42 PM
88 rex's Avatar
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
Your looking for the Civic/CRX SIR style hood, don't say the reverse hump...</TD></TR></TABLE>
Old Apr 7, 2006 | 02:48 PM
si0385.'s Avatar
Default Re: (88 rex)
how much are these fiber images hoods? how well was the fitment ?
Old Apr 7, 2006 | 02:54 PM
88 rex's Avatar
Default Re: (si0385.)
I bought mine used, but it was in great condtion. It was local so I didn't have to fork over the $$$ for shipping. The fitment was good. Some people have problems with fitment, some don't. It's a hit or miss kind of thing.
Old Apr 7, 2006 | 05:30 PM
thrty8street's Avatar
up
Old Apr 7, 2006 | 06:15 PM
.Grimace's Avatar
footwork mastery
Default Re: anyone here actually have those jdm style CF hoods for usdm civic/crx's? (thrty8street)
if you're buying it for clearance what about one of the zc hoods? They just got a litttle hump
Old Apr 7, 2006 | 06:19 PM
ludesrv's Avatar
Default Re: anyone here actually have those jdm style CF hoods for usdm civic/crx's? (PurpleEKHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PurpleEKHatch &raquo;</TD></TR><TR><TD CLASS="quote">if you're buying it for clearance what about one of the zc hoods? They just got a litttle hump</TD></TR></TABLE>
Those are only designed to clear the giant cam gear of the DOHC ZC...too bad the stock USDM can clean it no problem...
Honestly, your local speedshop (haha...speedshop) that does imports can get this hood if they do appearance aswell. I don't know who makes them, but I'm sure any CF hood making companies can do them.
Old Apr 7, 2006 | 06:25 PM
si0385.'s Avatar
anybody know if a eg radiator will clear with a jdm style hood
Old Apr 7, 2006 | 06:30 PM
ludesrv's Avatar
No. The fitment is exactly like the USDM only you have maybe 1 extra inch of clearance at the peek, the middle.
EG rads have to lean or have the support cut out. I hear 95 Neon rads fit, but they have in line rad caps...so that suck. Cut and fab the lower cross member to accept one.
Old Apr 7, 2006 | 06:44 PM
.Grimace's Avatar
footwork mastery
Default Re: anyone here actually have those jdm style CF hoods for usdm civic/crx's? (ludesrv)
Those are only designed to clear the giant cam gear of the DOHC ZC...too bad the stock USDM can clean it no problem...</TD></TR></TABLE>
well he said he said he had clearance issues so i threw it out there
Old Apr 7, 2006 | 06:58 PM
ludesrv's Avatar
If you use a mounting kit there is no clearance issue. If you have cheap mounts then I can see your valve cover hitting the hood. HASport kits are nice and tight, if you can shut the hood, it won't rub.
Old Apr 7, 2006 | 07:05 PM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">If you use a mounting kit there is no clearance issue. If you have cheap mounts then I can see your valve cover hitting the hood. HASport kits are nice and tight, if you can shut the hood, it won't rub.</TD></TR></TABLE>I have HASport mounts and I have clearance issues. My VC rubs pretty good on the hood. But I dont know if having a B20 makes any difference.
Old Apr 7, 2006 | 07:13 PM
88 rex's Avatar
Default Re: (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">I have HASport mounts and I have clearance issues. My VC rubs pretty good on the hood. But I dont know if having a B20 makes any difference. </TD></TR></TABLE>
With the hasport mounts and a B18/B20 you need to cut out some of the webbing from the underside of the stock hood. Hasport designed the mounts for the B16 and not exactly for the taller B18/B20 blocks. I don't believe they plan to change that though due to not wanting to sacrifice precious ground clearance.
Old Apr 10, 2006 | 09:22 AM
crxalex's Avatar
My old yellow mugen SiR, with one piece carbon bonnet.
Old Apr 10, 2006 | 09:34 AM
crxalex's Avatar
Whoops, I just reread your thread title! You're after Jdm style bonnets for USDM CRX's.
Ah well, theres my old SiR anyway.
Old Apr 10, 2006 | 11:43 AM
drachir's Avatar
x3. The Hasport mount kit still has clearance issues.
But then again B18B, B18C, B16B, B20 all have higher deck height than B16A. Not sure if you'll have clearance issues with B16A.
Old Apr 10, 2006 | 12:07 PM
JODA GOT SOL's Avatar
CF hoods
Old Apr 10, 2006 | 01:05 PM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StickyGreen &raquo;</TD></TR><TR><TD CLASS="quote">
anymore shots of this ride?
http://www.imagestation.com/al...59711
PsychoSiRex
Honda Civic (2006 - 2015)
Apr 12, 2007 09:31 PM
djphonics
Sep 23, 2006 12:02 AM
Driven
Apr 14, 2006 11:11 AM
thapimpfromchi
11
Oct 1, 2005 04:01 AM
91CivicSir
32
Apr 24, 2005 05:09 PM
