Interior help...
Old Apr 7, 2006 | 11:13 AM
dagur dreymandi's Avatar
Default Interior help...
Hey I have a 89 CRX si...
I am in the process of sealing off some leaks and have pulled up the carpet and all of the interior... Under the carpet is this black tar-like layer... is there any way to remove this stuff cleanly?... since water has been sitting in there for awhile part of it has gone soft so i wiped it away but now I wouldnt mind cleaning up the whole area... so is there any product that can assist me in removing this gunk?...
~J
Old Apr 7, 2006 | 11:25 AM
VenWood's Avatar
Default Re: Interior help... (dagur dreymandi)
You need to get it really cold and then it will come up with a chisel. Use dry ice or do durring the winter time.
Old Apr 7, 2006 | 11:26 AM
cbp_crx's Avatar
Default Re: Interior help... (VenWood)
yeah get urselft some dry ice as already mentioned, then it comes off pretty easy
Old Apr 7, 2006 | 12:07 PM
CRX Toad's Avatar
That stuff is sound deadening matterial. As stated get some dry ice and a rubber mallot and it will come off. Then to get the residue you will have to get some kind of solvent.
92 si hatch's Avatar
maybe a good degreaser or something
Old Apr 7, 2006 | 12:18 PM
Default Re: Interior help... (CRX Toad)
hey "CRX Toad" I'm a new member and dont have pm'ing privleges i guess.... i need one of your trusty climate control plates.... add me on msn if you have it... josh.cullen@hotmail.com
Old Apr 7, 2006 | 12:43 PM
harmonator84's Avatar
yea i need to take that stuff off too..
i think i am just going to try scraping it off, maybe with some solvent
Old Apr 7, 2006 | 03:02 PM
rsca_crx's Avatar
Default Re: Interior help... (harmonator84)
dry ice is your friend if you want to take it out. search "sound deadening" and you'll see some write ups.
but perhaps reconsider if this is your street car. it does get quite a bit louder (pebbles and ****) when you take it out. and it makes your car sound like a tin can - read "really cheap"- to anyone who doesn't understand.
i've taken it out of my cars (along with anything and everything that doesnt make it go, stop, or turn), and can vouch for the 28 lbs it saves, and also the fact that it is 28 lbs from the place where removing it is doing the least for you (low and in the middle).
on a dd, i'd leave it in.
crsgrge
18
Nov 6, 2014 11:25 AM
4serioferio
47
Jun 13, 2013 04:17 PM
baastard
Mar 8, 2005 08:52 PM
SiRex91
11
Jun 18, 2003 04:55 PM
