denji projector bulb?
what bulb size does the 93 civic denji projector uses? if anyone has a pic of the bulb holder too, that would be great. i bought used denji projectors off ebay and apparently they have no locking mechanism to hold the bulb in. Guess i need a picture to see what i have to make...any helpful replies would be greatly appreciated...thank you
-tt
p.s.
if this is in the wrong section, mods please move, thank you
-tt
p.s.
took a few pics of my denji's for you.
one H3 bulb holder and bulb.
http://www.b18c5eg.com/images/H3_holder1.jpg
http://www.b18c5eg.com/images/H3_holder2.jpg
http://www.b18c5eg.com/images/H3_holder3.jpg
http://www.b18c5eg.com/images/H3_holder4.jpg
good luck making them, it's sort of a spring wire type stuff. Reminds me a lot of piano wire.
depending on the vintage of the Denjis it could be two different bulbs.
Is the high beam reflector round (halos) or rectangular?
I have a set of both so let me know so I can take the correct pics for you.
i'm pretty sure it is an h3 buld and yes there is supposed to be something to lock them in it is a piece of metal rod real thin shaped oddly and it squeezes together and under a hook supposed to be on your lights two arms hang down and hold the light in place
the high beam in the rectangular high beam Denji's (old style) are H1. (they look like this right? http://www.e-hatch.com/images/...1.jpg )
pics of the holder
http://www.b18c5eg.com/images/H1_holder1.jpg
http://www.b18c5eg.com/images/H1_holder2.jpg
http://www.b18c5eg.com/images/H1_holder3.jpg
http://www.b18c5eg.com/images/H1_holder4.jpg
pics of the holder
those are pics of the back of the low beam, i need pics of the back of the high beam because my projectors didn't come with any locking mechanism to hold the bulbs in. Now if one of those 4 pics are the high beam, which one is it? they look like low beam to me. sorry in advance if i'm looking at it wrong
-tt
-tt
my first post with four pics was of the low beam. The second set of four pics were the high beam.
note the different bulb in the second set of pictures.
The low beam uses a H3 bulb which has a wire running off to the side of it. The high beam uses a H1 bulb that has a terminal for the wire on the end of it.
in case you have trouble by the wiring of the bulbs. My low beam is a PIAA (written on the bulb base) the bulb I have in place for the high beam right now is a FET.
Petah
10
Apr 16, 2002 06:55 PM
