i have problem with my short shifter..
Old Apr 7, 2006 | 09:00 AM
Walterronny's Avatar
Default i have problem with my short shifter..
i just arrived my short shifter today,but i see that the package is a bit broke ,and only is a short shifter plus a but plus a the ****.. i think that they lack more pieces.. what do i need? i am seeing this how-to
https://honda-tech.com/zerothread?id=1007935
and i need a rings ,and the sleeves, i think that it is assembled in rhort shifter..
i just to do a pics..
only it arrived me this.
is it the sleeves?
Old Apr 7, 2006 | 09:09 AM
KiddEng's Avatar
Default Re: i have problem with my short shifter.. (Walterronny)
the bearings in there serve the purpose of the sleeves/o-rings in the B&M shifter...
for your shifter all you do is un-bolt the stock shifter, and re-install the new short shifter. using the same bolt and nuts to tighten it back down.
this same bolt you loosen'd, reuse on your new shifter.
pretty straight forward
Old Apr 7, 2006 | 09:12 AM
ah ok man...thank you
Old Apr 7, 2006 | 09:14 AM
KiddEng's Avatar
Default Re: (Walterronny)
did you get the ES shifter bushings too? that'll really help with the "crisp-ness" of the shift and make it nice and tight
if not, i'd recommend them also.
Old Apr 7, 2006 | 09:19 AM
Default Re: (KiddEng)
ES? (what means¿)no man, i did but a short shifter and it arrived only that.. where can i buy the bushing?
thank again
Old Apr 7, 2006 | 09:21 AM
I3ooS710's Avatar
http://www.inlinefour.com has them.
Old Apr 7, 2006 | 09:31 AM
a guy say me that it's horrible... he has the same... what do you think?
I am frightening myself
Old Apr 7, 2006 | 02:22 PM
KiddEng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Walterronny &raquo;</TD></TR><TR><TD CLASS="quote">ES? (what means¿)no man, i did but a short shifter and it arrived only that.. where can i buy the bushing?
thank again</TD></TR></TABLE>
sorry ES = Energy Suspension
if you look back at the B&M thread, if you notice the red bushings that are on the ends of the shift linkages...those are the bushings im talking about. they really firm up the feel of the shifts and take away alot of the slop.
heres a shot of them:
and
you might as well install those while your down there... unless you like to do it twice like me
PS don't be frightened, changing out your shifter is pretty easy and straight forward, just follow that "how-to" for removal and install and you'll be set
Old Apr 9, 2006 | 01:31 AM
ok brother, thank you alot!
is those that can i have to buy?
http://www.inlinefour.com/ensusshifsta.html
or those..
http://cgi.ebay.com/ebaymotors...wItem
again, thank you
Old Apr 9, 2006 | 06:22 AM
KiddEng's Avatar
yep either place will work, whichever is cheaper i guess or will get it to you the fastest, seeing that your in Spain.
just make sure you get the right bushings for your engine. I believe B-series (DOHC) motors use a different size bushing than D-series (SOHC) engines.
or else the "circular" bushing will not fit...
Old Apr 9, 2006 | 08:32 AM
Contender25
Guest
Posts: n/a
If you got a b16a in 92-95 models i would assume you get the 93-97 del sol DOHC bushings for you're shift linkage.
Old Apr 9, 2006 | 08:42 AM
CBEengineering's Avatar
Default Re: (Contender25)
or integra (all). dohc is 16.1101g and sohc is 16.1102g i believe
correct me if im wrong cause i know ya will
Old Apr 9, 2006 | 08:50 AM
ok, thank you brother, i appreciate your help.
i'll buy it (from Ebay)
thank you again.
Contender25 , ok thank you too. so , del sol DOCH 93/97 is compatible in a lot pieces with my car (eg6 94 B16a2 ) not?
Thankyou
Old Apr 9, 2006 | 11:36 AM
BigGreenAuto's Avatar
hey... my ES bushings didnt come with any lube
Old Apr 9, 2006 | 11:44 AM
Default Re: (BigGreenAuto)
i suppose ES that i just bought neither... but i have grease .. it would be worth..i think so.
Old Apr 9, 2006 | 05:59 PM
Contender25
Guest
Posts: n/a
Yep when you go to auto parts stores to buy most common parts for you're b16 sirII, you are gonna tell them 93-97, somewhere in that range honda del sol VTEC, basically if they ask the DOHC 1.6 liter of course. DOHC means dual over head cam, but yeah if you order them from their they should be that model in particular.
Old Apr 9, 2006 | 08:20 PM
no when he goes to the auto parts store he asks for parts for a EG6 VTi when he orders parts off of ebay there for a 93-97 Del sol Vtec
Old Apr 9, 2006 | 08:52 PM
Contender25
Guest
Posts: n/a
Eh forgot this guy lives in spain, sorry bro.
Old Apr 10, 2006 | 09:00 AM
haha yep, i live in spain, but i normally buy off ebay. but if i have to go to HONDA , i asks for Civic 5th VTI lol... in ebay i buy searching for HOnda civic 92-95 (there are very very much items too) .. but i didnt know that i would can to searh for Del Sol 93-97 .
Thank you.
Old Apr 10, 2006 | 09:03 AM
Contender25
Guest
Posts: n/a
Virtually almot anything can be swapped from the del sol and four door eg models and coupe and hatchbacks. Not everything but half the stuff anyways, since all the front half of the cars are the same...
Old Apr 10, 2006 | 09:05 AM
ZipTieGUy's Avatar
where the hell did you get that generic *** shifter in crappy *** packaging
Old Apr 10, 2006 | 09:08 AM
EX-T's Avatar
I just read this whole thread b/c I like trying to figure out what the original poster was saying!!! HAHA good luck!
Old Apr 10, 2006 | 12:55 PM
nono i refered only engine with Del sol VTI that it has too B16a2 .
Old Apr 10, 2006 | 12:56 PM
Default Re: (ZipTieGuy)
ebay
phatboy4242
Aug 21, 2007 08:08 PM
Undercover_Skank
Sep 20, 2004 06:20 PM
