o2 simulator installation
i recently purchased a casper o2 simulator and had a few questions regarding installation. first of all, i looked over the directions, and apparently the colors of the wiring isnt correct. i was wondering if anybody knew which colors matched up to eachother, and if installation is easier from inside the car or underneath. if anybody has any info that would be appreciated. thanks so much.
fyi..the secondary o2 sensor has 4 wires, 2 black, 1 green, 1 white
and the simulator 3 wires a purple, black, and red
like $45..but back to topic!
wow nevermind..ordered wrong part #
will update if i need help when correct part comes in.
sorry all.
Modified by easyFOsheezy at 4:39 AM 4/7/2006
sorry all.
k the simulator is finally installed. i drove the car around for about 10 miles, but the CEL is still on. should i reset the ECU or keep driving around? any info welcome. thanks.
Heh, O2 simulators are crap.
Go with another solution.
http://www.s2ki.com/forums/ind...&st=0
Anything else is not worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onyx00 »</TD></TR><TR><TD CLASS="quote">Heh, O2 simulators are crap.
Anything else is not worth it.</TD></TR></TABLE>
Not so.
I've sold several to help out my friends locally and here on h-t.....
Just ask JDM Factor, kengs, pyromaster, B18C5 EH, etc.
Not so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXnorway »</TD></TR><TR><TD CLASS="quote">uhm, does anyone make/sell a o2 simulator that could be plugged into the wiring harness </TD></TR></TABLE>
afaik, I'm the only person who makes a plug and play solution.....
Bahahah.....u spent 45 bucks???? All I did was wrap it in tin foil and strap it to the shift linkage and no CEL.....But now I have Hondata so I just deleted that secondary 02 and I have been happy as a clam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC »</TD></TR><TR><TD CLASS="quote">care to elaborate on how that works?</TD></TR></TABLE>
.....it changes the signal/ voltage that the ecu sees from the 2ndary o2 sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">
.....it changes the signal/ voltage that the ecu sees from the 2ndary o2 sensor. </TD></TR></TABLE>
oh, so you still have to have a secondary o2 sensor plugged in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC »</TD></TR><TR><TD CLASS="quote">oh, so you still have to have a secondary o2 sensor plugged in.</TD></TR></TABLE>
that is correct. it can either be in the cat or test pipe; or you can even pull it up into the cabin.
You guys don't need that crap.
I took a simple Spark Plug Non-Fouler and this made things work great! No codes at all in 2000+ miles!!
Here is the link:
http://www.amazon.com/gp/produ...84181
Just drill it out to fit the O2 sensor and plug it in. You are good to go!
Here is the link:
