Suspension & Brakes Theory, alignment, spring rates....
wut is a good suspension for scca
Old Apr 6, 2006 | 06:52 PM
94IntegraLs04's Avatar
Default wut is a good suspension for scca
i need a new suspesion set for scca any help
Old Apr 6, 2006 | 07:23 PM
Voyage34's Avatar
Default Re: wut is a good suspension for scca (94IntegraLs04)
what class?
Old Apr 7, 2006 | 05:56 PM
Default Re: wut is a good suspension for scca (Voyage34)
street prepared i think
Old Apr 8, 2006 | 09:03 AM
Voyage34's Avatar
you might want to verify that, the rules vary greatly depending on your class, whether your doing solo or pro or rally...
but if you are doing street prepared, the all-purpose koni/gc will work, I would start with the stock rates for now until you learn how the car behaves and you can change spring rates from there.
youre limited on swaybars by this little phrase: "Non-standard lateral members which connect between the brackets for the bar are not permitted". this excludes pieces like the ASR or Comptech subframe braces, and depending on your chassis, i/e EK, it would be somewhat unwise to put a bar larger than about 19mm on without one of those items. You can use a beaks kit, but there are pictures in other threads of an ITR bac that completely ripped a chunk of subframe out with the beaks kit still attached.
Good tires as well.
If you havent already, ask over in RR/AX, but verify the class youll be in, read the rules over a few times (http://www.scca.org/_filelibrary/Fil...solo_rules.pdf if it is indeed SP), and search through their archives first, see if your specific questions have already been covered.
endwell17
14
Sep 10, 2011 12:49 PM
electron_si
Suspension & Brakes
Oct 24, 2006 02:03 PM
JesseCRX
Suspension & Brakes
Jun 29, 2005 05:16 AM
pucho
Sep 10, 2002 02:36 AM
