How to remove shock and spring assembly??
Old Apr 6, 2006 | 06:03 PM
Ruskimafia's Avatar
Default How to remove shock and spring assembly??
I have a 4dr 2000 v6 accord and just got Tien H Tech springs. I was wonderning if anyone had a write up or pictures on how to remove the front & rear shock and spring assembly ?? Im doing the install myself with a couple of friends
Thanks
Old Apr 6, 2006 | 06:12 PM
Ross 2.0's Avatar
In a Junkyard near you.
#1 do you have a SAFE spring compressor? If no then don't even attempt it.
Old Apr 6, 2006 | 06:16 PM
Ruskimafia's Avatar
Default Re: (MooGoCow3)
yes i do i rented from auto zone and have a air compresor w/ power tools
Old Apr 6, 2006 | 08:09 PM
gianinline's Avatar
Default Re: How to remove shock and spring assembly?? (Ruskimafia)
I've tried a search on that, but didn't find any "how to" for 2000 accord or even 6th generation.
Might want to pick a haynes manual for that, hopefully they already have a manual for that model accord!
Old Apr 7, 2006 | 07:39 AM
Ruskimafia's Avatar
Default Re: How to remove shock and spring assembly?? (gianinline)
I was wonderning if any one had the haynes manual? and if they could make a copy off it or something to help me out
Old Apr 7, 2006 | 08:16 AM
SiR Accord's Avatar
you should just pick one up, they are only like 20 bucks and they will help you out in future projects.
Old Apr 7, 2006 | 08:20 AM
SpeedFreak77's Avatar
Default Re: How to remove shock and spring assembly?? (H Accord 22)
I bet you could even get one on ebay for $5.
Old Apr 7, 2006 | 08:42 AM
rgoins's Avatar
Default Re: How to remove shock and spring assembly?? (SpeedFreak77)
ehh i'd be weary of buying tools off ebay...
might end up with some that has "craftsman" stamped on it but it's made out of pewter or something
Old Apr 7, 2006 | 08:49 AM
SiR Accord's Avatar
Default Re: How to remove shock and spring assembly?? (rgoins)
i think he was talking about the haynes manual.
Old Apr 7, 2006 | 08:51 AM
Ross 2.0's Avatar
Ok noww that we have that established.
FRONT You just need to unbolt the U shaped (forget the name) bracket on the bottom of the strut and lay it on the ground. Unbolt the brake line and and ABS wire (if equiped).
Then from the top take off the three bolts from the tower and the strut falls out.
***BE VERY CAREFUL WITH THIS STEP!**
Place the comprssor on the spring and compress it untill you can move it freely then remove the 14mm bolt from the top of the strut. (if it spins the strut release a little bit of spring tension and it should begin to move, be sure to re-tighten the compressor once the bolt begins to move, if that doesn't work just use a hand wrench and a allen key)
keep track of the strut caps and parts so everything goes back in the right order.
If you have any more questions just ask!
The rear is the same concept just different mounting points. The top bolts can be found behind the trunk side liners.
Old Apr 7, 2006 | 01:39 PM
Ruskimafia's Avatar
Thanaks alot.
niceprelude
Mar 7, 2009 06:34 AM
tvomalley
Oct 26, 2008 07:58 PM
romani
Feb 21, 2005 06:48 PM
fe519
Jul 6, 2003 09:57 PM
