Could I use a D16A6 block+head in my DPFI d15b2?
Old Apr 6, 2006 | 05:12 PM
mengy007's Avatar
Default Could I use a D16A6 block+head in my DPFI d15b2?
My block is getting no compression. I do not have the money to do an all out mpfi swap although I would like to. For now I just need my car to run so I can get to and from work. My bro is doing a ZC swap in his 90 crx and his d16a6 is still running good and strong. He is using his old harness w/ splicing some wires so I can't use his harness for mpfi change over... anyhow with that said, I would just like to know if I can simply put my IM and EM on his d16a6 block and head and have everything running.
Old Apr 6, 2006 | 05:30 PM
SD_Lurker's Avatar
HT White Ops
Default Re: Could I use a D16A6 block+head in my DPFI d15b2? (mengy007)
Why dont you just have your car wired and change it over. You have the expansive parts all you need to do is get all the MPFI parts and rewire it.
Old Apr 6, 2006 | 05:36 PM
mengy007's Avatar
Default Re: Could I use a D16A6 block+head in my DPFI d15b2? (nicks_jdmstyle_ef9)
I've already said that I do not have the money or time right now to get the parts for the mpfi setup. All I need to know is will it work?
Old Apr 6, 2006 | 05:40 PM
SiMateoAko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mengy007 &raquo;</TD></TR><TR><TD CLASS="quote">I've already said that I do not have the money or time right now to get the parts for the mpfi setup. All I need to know is will it work?</TD></TR></TABLE>
It will work, but it will be really running lean (1.5L computer on a 1.6L engine).
I'm confused how you don't have the time to do an MPFI swap but you have the time to swap an engine.
Old Apr 6, 2006 | 05:42 PM
SD_Lurker's Avatar
HT White Ops
I am sure anything is possible you just have to put your mind to it! I have a few questions for you. YOur brother is giving you the entire engine. Go to the junkyard and buy the plugs needed to complete the MPFI. I will sell you the injector box for 20 buck plus shipping. I am sure you can get all the wiring you need for less than 40 dollars. then all you have to do is ask for a diagram and wire it up. Just do it the right way the first time.
Old Apr 6, 2006 | 05:43 PM
SD_Lurker's Avatar
HT White Ops
sorry and you will need the ECU. I seriously think you can get all the parts for less than 100 dollars and your brother is giving you the motor for free so your set.
Old Apr 6, 2006 | 06:00 PM
mengy007's Avatar
Default Re: Could I use a D16A6 block+head in my DPFI d15b2? (SiMateoAko)
because i do not have:
1) extra harness I can pick and choose parts from
2) extra ECU to run the new setup with
and I do have
d16a6 block / head / IM and thats about it
Old Apr 6, 2006 | 06:02 PM
mengy007's Avatar
I only get 2 days off and then it's back to work so it's not like it's my project car on the side that i can just work on when ever.. like I said, as long as it works.. I'm planning to do the mpfi swap later on once I get my new car
Old Apr 6, 2006 | 06:03 PM
mengy007's Avatar
I'm not worried about money. It's time that's the killer. How much would it be to ship to Southern Cali.?
EF9ZC's Avatar
dont need an extra harness, ecu can be bought off ebay for next to nothing or get one at junk yard.
Old Apr 6, 2006 | 06:05 PM
mengy007's Avatar
Default Re: (EF9ZC)
I've already checked all the local junk yards. The closest one is 30mins away. They do not have the parts I need.
Old Apr 6, 2006 | 06:08 PM
EF9ZC's Avatar
all u need is an ecu man buy it off of ebay when your ready for write up...http://stereophonik.com/gutterslide/...rror/mpfi.html then u need butt conetors or soldering gun. soldering gun from lows with butane and solder is like 25 bucks man. Spend 50 more bucks and your straight if you need the ecu i got a brand new si computer
mengy007's Avatar
Default Re: (EF9ZC)
How do I do the mpfi swap without an extra harness to pick from? I've looked at the wiring diagrams, it'll take me a whole day just to do the harness. I've got to do 2 motor swaps in 2 days. I'm just looking for the easiest way to get my car running so I can go to work. I'm not saying I will not do the mpfi swap.. just not right now.
Old Apr 6, 2006 | 06:09 PM
mengy007's Avatar
Default Re: (EF9ZC)
Like I said, money is not an issue here. It's time.
Old Apr 6, 2006 | 06:10 PM
EF9ZC's Avatar
Should not take more then 1 day to do each engine at the longest even if its first time as long as u got all parts
Old Apr 6, 2006 | 06:13 PM
mengy007's Avatar
Default Re: (EF9ZC)
Yeah I've done swaps before just that we had plenty of time before.. now it's a matter of just get the car operation asap.
I really do hate my dpfi. In the near future I plan on droping in a B20turbo setup so no need for all that mpfi change over. I just need my car running right now so I can continue to go to work.
Old Apr 6, 2006 | 06:28 PM
EF9ZC's Avatar
Well with no compression guy i dont know what your going to do. Good luck tho this thread is pointless
Old Apr 6, 2006 | 06:43 PM
mengy007's Avatar
Default Re: (EF9ZC)
Well the point of this thread was to see if a d16a6 block + head would work with a d15b2 IM and wireharness / ecu.. and i got my answer - running a little lean is just fine with me. Just because I'm not gonna do what you wanted doesn't mean it's pointless.
Old Mar 22, 2010 | 02:34 AM
steeltoe's Avatar
additional great info to help clarify for some
https://honda-tech.com/forums/showth...6a6+head+d15b2
hopefully it'll save someone some grief
Johnboy0620
Feb 27, 2018 06:18 AM
nitewolf
Mar 14, 2010 06:48 PM
ZAKU
Jan 7, 2009 07:20 PM
JJ's civic
Jan 9, 2007 03:41 PM
SiMateoAko
Aug 14, 2005 11:34 PM
