b18 from 91 acura ls
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3s0n3 »</TD></TR><TR><TD CLASS="quote">USE THE RED SEARCH. </TD></TR></TABLE>
x3.14
x3.14
I did a little search on that I know it's possible but It did not tell me what model,year,make where I can get the axle, mount and other parts that need to complete a swap into a crx. I have never done this before. so please go easy on me. but if you need know how about coverting a 914 porsche into v8 that I would be expert into it.
well alot of the swap would depend on what model crx you have. let us know that and we can point you in the right direction. but you will def need a motor mount kit, shift linkage, ecu, axles from 90-93 integra, 90-93 integra half shaft, radiator hoses from a 90-93 integra,Rear mount bracket from 90-93 integra, if you have an hf model then you will need to change the hubs to fit the axles and also check out rywire.com for all your wiring needs. just to name a few things
you will also have to buy lots of little things here and there and it all adds up.. just have cash on hand. your best bet is to find a whole teg and get all the parts you need off of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lito1208 »</TD></TR><TR><TD CLASS="quote">thank you hondaFerris for your help. just wondering what do I expect from this motor hp? 160 or higher
More like 130hp..
Like hondaferris said you'll need an aftermarket mount kit and linkage..Or cut and reweld the stock linkage..90-93 integra axles..You Have to remove the dust ring from inside the crx hubs otherwise the axles will bind..Make a decent size dent on the innder fender for alternator clearance..Most mount kits require you to use the 90-93 integra rear mount bracket..Also take the radiator from the integra if you can (if its in good shape ).
More like 130hp..
