will 1.5 spark plug wires work on a 1.6?
Old Apr 6, 2006 | 11:06 AM
classciv's Avatar
Default will 1.5 spark plug wires work on a 1.6?
spark plug wires are really crappy on my 91 crx si but i have a nice set on my 90 1.5L lx 4 door engine. will the wires swap? i am thinking no but it is a shot in the dark
Old Apr 6, 2006 | 01:05 PM
ludesrv's Avatar
They should, but the firing order is different so they might be a little tight in some areas.
I beleive my 1.6 has 1.5 wires on it...it runs fine.
Old Apr 6, 2006 | 01:56 PM
classciv's Avatar
Default Re: (ludesrv)
well it is worth a shot, thanks
Old Apr 6, 2006 | 03:26 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">but the firing order is different</TD></TR></TABLE>
Hmmm, i was pretty sure that the firing order was the same for D-series engines 88-00.
What would firing order have to do with whether spark plug wires would work or not?
In short, yea, it should work.
Old Apr 6, 2006 | 03:28 PM
dr_latino999's Avatar
Default Re: (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm, i was pretty sure that the firing order was the same for D-series engines 88-00.
In short, yea, it should work.</TD></TR></TABLE> And for future reference, you can also use your 88-91 wires on any SOHC cam from 92-95, they just won't seat all the way down on the valve cover.
kixcrx
Aug 28, 2007 11:38 AM
Rob.
Jun 14, 2007 08:33 PM
RACEPAK
Oct 25, 2004 07:04 AM
osuperjohno
Jun 2, 2004 03:25 AM
B00ST2nR
Dec 14, 2003 02:03 PM
