crome ecu setup?
ok, ive read about all i can take on the search feature and im still lost as to the steps to run crome on my p30, can someone just give me a step by step, doesn't even need to be too indepth, approach to how to install, setup, and run crome on my ecu.
exp. 1. take out ecu
2. socket it
3. buy rom burnner
4. etc etc.....
im just getting confused and ive read about 10 different contradickting things
2. socket it
3. buy rom burnner
4. etc etc.....
pre. buy chip kit or parts to chip ECU, buy burner. To tune you will need a wideband, an ostrich or similer is recommended but not required.
1. remove ECU
2. http://www.pgmfi.org/twiki/bin...DMP30
3. create base map (there is a topic on PGMFI about this but I can't find it right now)
4. increase the idle resolution if you want to (good idea) http://forum.pgmfi.org/viewtopic.php?t=8651
5. burn to chip
to tune.... (you need Crome Pro or a datalogging software program for this)
6. add datalogging cable or connector to CN2(I think that's what it's labled, four pin connector, ~ center of board)
7. buy phone USB cable or TTL-RS232 converter to communicate to ECU from laptop.
I'm leaving out many steps so details can be filled in anywhere.
1. remove ECU
5. burn to chip
http://moates.net/ has everything you could need and more.
http://www.moates.net/index.php?cPath=25_37 <--- for the kit. Yes he called it an Uberdata kit, but it's the same thing.
ok, so if i get that kit, i install it, then i get a rom burner and like chrome and burn all that too the rom, then just plug and go?, then i can run ecu pro with my laptop in my computer with all the displays and data log
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG93si »</TD></TR><TR><TD CLASS="quote">ok, so if i get that kit, i install it, then i get a rom burner and like chrome and burn all that too the rom, then just plug and go?, then i can run ecu pro with my laptop in my computer with all the displays and data log</TD></TR></TABLE>
to get it running on a base map...
get the kit, install it.
get a rom burner (moates.net sells those too)
download Crome and various plug ins that you want from PGMFI.org or tunewithcrome.com
create your base map (depending on your setup, search PGMFI.org for someone with the same type of setup or create your own using the OEM map directory - http://www.pgmfi.org/twiki/bin...Codes )
burn it into the EEPROM, install it in the ECU.
stevenDAtegra
Engine Management and Tuning
12
Dec 18, 2009 09:37 AM
