Starting PROBLEM!!!!!!!!!!!!!!!
Old Apr 6, 2006 | 10:12 AM
CaliforniaHighwayPatrol's Avatar
Default Starting PROBLEM!!!!!!!!!!!!!!!
I had a CRX w/ a B16 for about 3 years and I sold it and just bought a 1994 Honda Civic EX (You can view the pics of the car in the picture section). I sometimes have trouble starting the car. It only happens when I do not drive the car for about 4 hours and the car sits there. If I turn it on within the 4 hours, it starts up right away. I took it too a mechanic and he said he thought it was the battery because if the battery sits to long the water drops. So I replaced the battery and nothing happened. When I go to start the car the starter and battery sound fine. I hear a noise like it is going to engage and I feel the car jolt and making a starting noise but it will not turn on. It takes like 2-4 tries and it will finally start. To rephrase things, the car does not turn over when I try to start it if it has been sitting for a while. Is this a starter problem? A fuel delivery problem?
Please Help It Really Bugs Me!
Old Apr 6, 2006 | 10:52 AM
skratchnsnift's Avatar
fuel. check your pump and filter. does it drive well?
Modified by skratchnsnift at 1:16 PM 4/6/2006
Old Apr 6, 2006 | 12:02 PM
The car drives beautifully. It starts perfect if the car has been driven with like a 4 hour time frame, otherwise it takes like 2-5 tries.
Old Apr 6, 2006 | 12:18 PM
B18C4-T's Avatar
Default Re: (CaliforniaHighwayPatrol)
Does the motor turn over, or does it sound like the battery is dead and just click? If it just clicks I'd check the starter. If it turns over but doesn't start then check the ignitor in the distributor. Larry
Old Apr 6, 2006 | 04:16 PM
billy30364's Avatar
Default Re: (B18C4-T)
Had same problem for long time, I changed the ignition coil didn't really work. I changed my alternator now starts up just fine
Old Apr 6, 2006 | 04:19 PM
JDM-97CX's Avatar
Default Re: (billy30364)
Let the car sit for a while, then get in it and make sure everything is turned off. Put the key in the on position and listen for a hum from the back of the car, it should last for about 2-4 seconds. That is the fuel pump priming the fuel lines.
Old Apr 6, 2006 | 05:32 PM
It just doesn't turn over. I have a new battery and starter.
Old Apr 8, 2006 | 03:39 PM
Replaced the Fuel Filter and Spark Plugs and it still does it.
Old Apr 8, 2006 | 03:46 PM
Walterronny's Avatar
did you check the fuel pump?
Old Apr 8, 2006 | 04:47 PM
No, how would I check if it is the problem?
Old Apr 8, 2006 | 07:07 PM
Wharbone's Avatar
When you turn your key to the on position, can you hear your fuel pump kick on (under rear seat)?
Old Apr 8, 2006 | 07:38 PM
I hear it turn on and I can tell it starts to primer the fuel filter
Old Apr 9, 2006 | 06:38 PM
I put on a B&M Fuel Pressure Gauge on today and found out it is dropping fuel. So it is either the injectors are leaking, the regulator or the fuel pump.
Old Apr 9, 2006 | 07:07 PM
solofthesouth's Avatar
Default Re: Starting PROBLEM!!!!!!!!!!!!!!! (CaliforniaHighwayPatrol)
I am having the exact same problem. i put new what i told was newer fuel injectors into my car, and all my problems started after that. how can you tell for sure if its a fuel pump?
Old Apr 9, 2006 | 07:15 PM
schardbody's Avatar
dude, if its not turning over its not fuel or spark, its a defective battery, starter ignition switch or clutch saftety switch. could be a few other things as well, but those are most likely.
Old Apr 9, 2006 | 07:27 PM
Default Re: (schardbody)
well it cant be an injector leak, if the car runs perfectly fine after a while. the starter--definaltey no. its either the fuel pressure regulator or fuel pump it sounds like. idk, i am just as baffled with my car as you are with yours.
Old Apr 9, 2006 | 07:35 PM
schardbody's Avatar
no, its going to drop pressure when it sits, the regulator doesnt close off when the engine is off, so slowly the pressure goes back to the tank. and like i said, fuel pressure, and spark wont cause the car to "not turn over"
Old Apr 9, 2006 | 07:47 PM
schardbody's Avatar
i figure by "not turning over" he means like the motor isnt turning over, wont crank over, no movement of the engine when the key is turned. not "it wont start".
Old Apr 9, 2006 | 07:49 PM
schardbody's Avatar
and so you know buddy, i wont stoop to your level of insults just because you cant read.
it wants to turn over, but its like its not getting enough fuel, so after 3 or 4 times of trying to start it starts, then it runs fine..and if i come back and start my car 10 mins later it starts, but if i let it set for 4 hours...it does it all over again
Old Apr 9, 2006 | 07:51 PM
schardbody's Avatar
so it just wont start on the first turn of the key, the way you say "wont turn over" means "the motor wont turn over" like no power to the starter.
Old Apr 9, 2006 | 07:52 PM
schardbody's Avatar
It just doesn't turn over. I have a new battery and starter. your words exactly
Old Apr 9, 2006 | 07:55 PM
like what he is saying--is that the car tries to turn over...but it just wont start. its something to do with the fuel, but we dont know what
Old Apr 9, 2006 | 07:58 PM
Syndacate's Avatar
it's a leak in the fuel lines, if the fuel pump wasn't working right you'd be getting problems while you drive, same with injectors, with a leak in the fuel lines ur just losing some gas as you drive, so it must not be that big if it's not breaking up while you drive.. Check the lines, check for leaks
Old Apr 9, 2006 | 08:00 PM
schardbody's Avatar
ah, he just worded it weird, if its cranking over and not starting then follow alllllllberrrrrrrtttttts advice.
