96-97 vs. 98-up JDM ITR engines
Old Apr 4, 2002 | 08:36 PM
JDC2's Avatar
Default 96-97 vs. 98-up JDM ITR engines
I'm thinking about buying a JDM ITR motor. Is there any difference within the motors from the 96-97 and 98-up JDM ITR motors? Minor or major differences please. Plus, do I need the axels, motor mounts, distributor, ect. Or can i use my exsisting ones I have a 95 LS. Thanks!
Old Apr 4, 2002 | 10:05 PM
DRFlickner's Avatar
Default Re: 96-97 vs. 98-up JDM ITR engines (JDC2)
Off the top of my head I know the 98+ has 4-1 header, while 96-97 has a 4-2-1 header. Don't quote me, but I believe 98+ JDM ITR has cams that are the same as the US Spec '00+, which is same as CTR.
I know you asked about motors, but if you are getting the drivetrain swap, the 98+ ITR has shorter gears than the 96-97, since the 98+ has the 4.785 final drive.
You will need the distributor too, since the LS one won't work. Axles from LS would work. Motor mounts are the same too.
Old Apr 5, 2002 | 07:47 AM
vtecteg's Avatar
you will have to do a obd1 to obd 2 conversion...a pain in the ***. I know it dosen't answer your question, but I just wanna make sure u know
Old Apr 5, 2002 | 10:32 AM
Jackson's Avatar
Default Re: 96-97 vs. 98-up JDM ITR engines (DRFlickner)
you are right on everything but the cams. ctr has its own intake cam different from all the itr cams.
Old Apr 5, 2002 | 10:42 AM
SCsol's Avatar
Default Re: 96-97 vs. 98-up JDM ITR engines (Jackson)
OBD conversion is not hard at all if you motor comes with UN CUT wiringg haraness just plug them in like you would a a OBD1 to OBD1 swap you wil have one plug left over on the passanger side its for the crank sensor you dont need it
gsr96cx
Mar 5, 2010 02:27 AM
failed
Oct 29, 2005 09:28 AM
Kid1320
Dec 19, 2002 12:44 PM
JDC2
Apr 6, 2002 01:11 AM
Rhetoric
Oct 7, 2001 07:10 PM
