alinement
Old Apr 6, 2006 | 07:16 AM
bkholloway's Avatar
Default alinement
i just swaped a 96 ex accord rear and by the look of it it looks like thedrivers side rear tire is cocked in the front of the tire will this be corrected by an alinement
Old Apr 6, 2006 | 08:12 AM
bkholloway's Avatar
Default Re: alinement
to add more to the question the ex rear is now on my 96 25 aniversery did i do some thing wrong on the install
Old Apr 6, 2006 | 08:22 AM
i_kick_turtles's Avatar
Default Re: alinement (bkholloway)
I'm not sure exactly what you did. But when you do suspension work, you typically need an alignment. You can take it to a shop and get a printout, usually for free that will tell you if you are out of specs or not.
Old Apr 6, 2006 | 09:18 AM
TouringAccord's Avatar
H-T Order of Merit
The shop should also let you know if there is a problem down there. (worn balljoints, worn bushings, bent parts, ect.)
Old Apr 6, 2006 | 01:48 PM
jli18's Avatar
Default Re: alinement (TouringAccord)
what kinda shop is that, do u know if there any in bay area?
Old Apr 6, 2006 | 02:03 PM
Default Re: alinement (jli18)
It's called an *drum roll* alignment shop.
Old Apr 6, 2006 | 06:22 PM
H-T Order of Merit
haha yeah, like I R Tylor said, an alignment shop.
I don't know of anything in the bay area but over here, I go to a hot rod shop that has always done great work with my cars (only alignments). My mom takes her car to Bell Tire, they give her print outs and told her the last time she was there that her ball joint was bad.
Just call around and see what shops people recommend in your area. Or post in the GDD and see if anyone from the bay area can point in the right direction.
Old Apr 6, 2006 | 06:44 PM
You could also check a phone book. It would probably be fasterest.
Old Apr 6, 2006 | 06:47 PM
jli18's Avatar
Default Re: alinement (I R Tylor)
great thanks guys! there is this local shop that do alignment for 40 bucks. do u think they will do the same good job as others do?
Old Apr 6, 2006 | 06:53 PM
Ya, $40 is pretty typical of what and alignment shop charges.
Old Apr 6, 2006 | 09:31 PM
HONCORD's Avatar
$40???
Yeah, if you want "toe and go"
Dont ask me how I know
Old Apr 6, 2006 | 09:39 PM
Default Re: alinement (HONCORD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONCORD &raquo;</TD></TR><TR><TD CLASS="quote">$40???
Dont ask me how I know</TD></TR></TABLE>
Heck ya, 40 bucks. I use to live in a town with only 2 alignment shops. Both were right around $40. The one I went to did a great job both times I went.
Old Apr 7, 2006 | 04:49 AM
H-T Order of Merit
it all depends on your area I guess.
Just make sure they are doing an all wheel alignment and make sure you get a print out of the specs.
SceneMotorsport
Northern California
12
Sep 16, 2009 03:27 PM
dnaazn326
Suspension & Brakes
Aug 3, 2006 08:35 PM
JohnEX
Nov 22, 2002 09:19 AM
Rain_man
Aug 13, 2001 09:16 AM
