Need help hooking up vac/coolant lines on Blox manifold - LS/T crx
Old Apr 6, 2006 | 06:40 AM
crex23's Avatar
Default Need help hooking up vac/coolant lines on Blox manifold - LS/T crx
Getting fairly close to getting the car done, but I can't figure out the vacuum and coolant lines on the new Blox mani. I've included some pics, I think I've got most of the lines right, please let me know about the other lines.
Also, I'm using a GE vacuum mani so I can plug the vac nipples on the Blox mani if need be. Basically I need to know which nipples are vacuum and which are for coolant.
Here's the pics:
'A' goes to the brake booster right?
Also in this pic, does the thing under the throttle body (not sure what its called) go on my new Blox mani?
Thanks for the help!
Old Apr 6, 2006 | 07:28 AM
importdude2000's Avatar
that the FiTv
it wont fit on blox
just bypass it
thats what i did on my ls skunk2manifold
ull have problems holding idle when its really really cold
for me in ca it drops but doesnt die out
Old Apr 6, 2006 | 07:32 AM
inspyral's Avatar
"A" goes to the brake booster. The small vac nipple on the front goes to your FPR. The small one in the back goes to Cruise Control. I think the the thing under your TB(fast idle valve or w/e it's called) can be run inline with the TB heater/IACV, and doesn't connect to the intake manifold.
Old Apr 6, 2006 | 09:20 AM
crex23's Avatar
Default Re: (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">that the FiTv
it wont fit on blox
just bypass it</TD></TR></TABLE>
what does bypass it mean, just don't plug it up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">"A" goes to the brake booster. The small vac nipple on the front goes to your FPR. The small one in the back goes to Cruise Control. I think the the thing under your TB(fast idle valve or w/e it's called) can be run inline with the TB heater/IACV, and doesn't connect to the intake manifold.</TD></TR></TABLE>
Can I plug the vac lines because I'm using a GE vac mani for the FPR, and I don't have cruise. And am I supposed to T the FITV off the EACV or just plug the nipple on the mani?
Old Apr 6, 2006 | 01:19 PM
plug everythign liek its spose too
then ull have 2 open ends
route em togheter
Old Apr 6, 2006 | 02:22 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Is this how everyone runs their IACV? I have a hose running from the front of the head where the upper rad hose connects to one of the nipples on the iacv...and i have the other one ran to that pipe like he does.
crxguy1991
Jul 2, 2012 02:29 PM
Timmyflys
Feb 26, 2010 12:30 AM
XSIintegra
Aug 27, 2008 06:03 PM
vtakvtrak
May 22, 2006 02:15 PM
menappi
Jul 17, 2005 07:47 PM
