running no cat results in better mpg?
Old Apr 5, 2006 | 09:56 PM
JTTeG_X's Avatar
Default running no cat results in better mpg?
will running no cat converter and a test pipe instead aide in increasing overall mpg?
Old Apr 6, 2006 | 12:14 PM
old man neri's Avatar
Default Re: running no cat results in better mpg? (JTTeG_X)
I doubt it. Probably just end up in you getting a nasty ticket and wrecking the air we breathe.
Old Apr 6, 2006 | 12:33 PM
v4lu3s's Avatar
RTFM
it iwll also get a constant check engine light as well.
Old Apr 6, 2006 | 08:45 PM
civicstar's Avatar
it will kill ur gas milage, that back pressure from the cat helps to save ur gas milage. less backpressure means less mpg but MORE POWER!
Old Apr 6, 2006 | 11:26 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: running no cat results in better mpg? (civicstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicstar &raquo;</TD></TR><TR><TD CLASS="quote">it will kill ur gas milage, that back pressure from the cat helps to save ur gas milage. less backpressure means less mpg but MORE POWER!</TD></TR></TABLE>
If you consider 2hp to be "MORE POWER" lol
Old Apr 7, 2006 | 12:58 AM
civicstar's Avatar
Default Re: running no cat results in better mpg? (JDM_Ej)
yep even 2 hp is more power, when ur up there in hp, even a few hp makes a difference, when i tuned my car and it first maxxed at 204, and getting 4 hp made a big difference
Old Apr 7, 2006 | 05:11 AM
v4lu3s's Avatar
RTFM
backpressure actually will kill power and economy.
running a test pipe and high flow cat showed a 1 hp diff on the dynoes I have done with a mostly stock h22.
Old Apr 14, 2006 | 08:32 AM
SVOboy's Avatar
Please don't drop your cat for gas mileage. Firstly, I doubt highly that it will help, secondly, don't be a ********, it's there for a reason, a good reason.
faxshatch
25
Apr 1, 2008 04:52 AM
riceball777
Dec 7, 2005 08:02 AM
HT Chaplain
Sep 19, 2004 03:34 AM
RS_91
10
Mar 31, 2003 12:02 PM
Mike95lude
Sep 10, 2001 04:45 PM
