obd 0 interchangeable distributors
Old Apr 5, 2006 | 08:25 PM
mrvang84's Avatar
Default obd 0 interchangeable distributors
I am getting ready to do a conversion from dpfi to mpfi. I need to know asap if you can use the d16a6 zc INTEGRA distibutor as well. I don't want to go out and buy an crx/civic si distributor if I don't have to. HELP ME PLEASE!!!
Old Apr 5, 2006 | 08:29 PM
crxnj's Avatar
Default Re: obd 0 interchangeable distributors (mrvang84)
D16a6 is not an integra engine..Thats a 88-91 civic/crx si engine..Im assuming you mean the D16a1 integra engine (which is not a zc engine) ..
Old Apr 5, 2006 | 08:36 PM
mrvang84's Avatar
Default Re: obd 0 interchangeable distributors (Mr.speaker)
but is it interchangeable though?
Old Apr 5, 2006 | 08:41 PM
crxnj's Avatar
What year is the integra engine..?
And what engine is the dizzy going on exactly?
Old Apr 6, 2006 | 09:43 AM
mrvang84's Avatar
it's an 87 integra with a dohc d16a engine. I'm trying to put it into my 88 civic dx d15b.
Old Apr 6, 2006 | 10:11 AM
jlicrx's Avatar
are you putting the Integra engine into your car? - not sure what you are saying you are trying to do - 86-87 Integra D16A1 distributors are vacuum advance for ignition timing and only work with the 86-87 Integra PG7 ECU - 88 DX chassis harness is not set-up to use that ECU
Old Apr 6, 2006 | 01:55 PM
mrvang84's Avatar
Default Re: obd 0 interchangeable distributors (jlicrx)
okay, what i'm trying to say is, i'm trying to convert my dx dual point fuel injection into multi point fuel injection. And in order to do that you have to use a crx/civic si/ex distributor. And I was thinking that since the crx/civic si/ex has the d16a6 and the integra has a d16a1, can I use the distibutor from the integra d16a1?Supposedly, they are both "zc" motors. That is my question.
Old Apr 6, 2006 | 02:01 PM
wickedEFguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrvang84 &raquo;</TD></TR><TR><TD CLASS="quote">okay, what i'm trying to say is, i'm trying to convert my dx dual point fuel injection into multi point fuel injection. And in order to do that you have to use a crx/civic si/ex distributor. And I was thinking that since the crx/civic si/ex has the d16a6 and the integra has a d16a1, can I use the distibutor from the integra d16a1?Supposedly, they are both "zc" motors. That is my question.</TD></TR></TABLE>
Just so you know I used to have a 90-91 Integra LS dizzy on my stocker D16 in my 91 CRX Si back in the day, bolts right up and is plug and play
Hope that helps
Old Apr 6, 2006 | 05:08 PM
mrvang84's Avatar
Default Re: obd 0 interchangeable distributors (wickedEFguy)
Finally, someone has some decent information. still want to know if the dohc d16a distributor will still bolt up to my dx d15b motor.
Old Apr 6, 2006 | 05:47 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrvang84 &raquo;</TD></TR><TR><TD CLASS="quote">it's an 87 integra with a dohc d16a engine. I'm trying to put it into my 88 civic dx d15b. </TD></TR></TABLE>
Cant do it then..Its a completey different distibutor system..And Im not even sure that the dizzy will even bolt up,,but even if it does it wont work..
99civicdxxx
Mar 13, 2010 05:39 PM
skip.two
Sep 12, 2005 07:18 PM
chwy_thoj
Oct 11, 2004 04:08 PM
FourthGenHatch
11
May 23, 2003 07:23 AM
irefuse2pay
Nov 1, 2002 10:37 AM
