what kind of welder to use?
Old Apr 5, 2006 | 08:06 PM
01-0720's Avatar
Default what kind of welder to use?
ok so im installing a jdm front end on my type r tommarow, and im going to be renting a welder
so i was wondering if someone could tell me what kind of welder i need to rent, i need to weld the front rad support, a few 2 or 3 inch beads, and a bunch of spot welds
also iv never welded before, but im goin to do a little practicing before i go to the car
thanks
eric
Old Apr 5, 2006 | 08:08 PM
ManBearPig4silly's Avatar
Mig will be easiest but I suggest you befriend someone who knows what they are doing before you tackle this project.
Old Apr 5, 2006 | 08:19 PM
01-0720's Avatar
Default Re: (I4sillypwr)
yeah i was thinking about this more, and i no someone with a shop, id better just clamp it up and take it to him and have him lay down a few welds
Old Apr 6, 2006 | 08:57 AM
tek_civic's Avatar
you should try to get to know the shop guy, he might let you weld some scrap metal after hours. welding is a great skill to have, even if your not going to use it this time.
Old Apr 6, 2006 | 02:55 PM
mike9571's Avatar
Default Re: what kind of welder to use? (01-0720)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">ok so im installing a jdm front end on my type r tommarow, and im going to be renting a welder
thanks
eric</TD></TR></TABLE>
A MIG welder is the best for your application. You dont need to run beads on a rad support. All of the welding being done is just plug welds.
Modified by mike9571 at 7:16 PM 4/6/2006
Old Apr 6, 2006 | 03:15 PM
LordAphotic's Avatar
any welder will do it... just get a cheaper fluxcore. and if you havent welded before practice a bit before or get someone who does know how to weld. its not hard.
Francois
Nov 25, 2007 04:46 PM
drewbie
21
Aug 30, 2007 08:15 PM
melovesboost
Welding / Fabrication
12
Apr 22, 2007 06:26 PM
junior40er
11
May 8, 2006 09:38 PM
dingusjt
Aug 20, 2003 08:32 AM
