replace wheel stud. I'VE SEARCH. can't find answer to my question
Old Apr 5, 2006 | 05:59 PM
lv6l's Avatar
Default replace wheel stud. I'VE SEARCH. can't find answer to my question
i broke 2 of the 4 stud off my front right wheel on my 94 civic cx. i want to replace it. the thing is is it possible to knock it off and stick a new stud in whitout removing the hub or spindle?? some people ahve told me that the stud is too long and will not fit between the gap to go in the hole. i dont know if this is true. so if anyone have tried or done this i need your help. thanks.
Old Apr 6, 2006 | 11:10 AM
lv6l's Avatar
bump
Old Apr 6, 2006 | 11:27 AM
Out of every
Default Re: replace wheel stud. I'VE SEARCH. can't find answer to my question (lv6l)
i could have sworn i seen this exact ? somewhere. ehh oh well you should have tried searching first but whatevs. i like helping
this should do it for you and its a DIY
https://honda-tech.com/zerothread?id=907985
Old Apr 6, 2006 | 07:28 PM
lv6l's Avatar
i saw that. and i have search. reason i'm asking in this thread is i'm asking is there a way to pound out the stud without removing the hub or spindle. anybody know?
Old Apr 6, 2006 | 08:10 PM
Out of every
Default Re: (lv6l)
no you cant.,... well you can take out 1 or 2 maybe but do it right.
Old Apr 6, 2006 | 08:40 PM
lv6l's Avatar
know any place that would charge pretty cheap to press out the hub? my friend told me go to justtires and they'll do it for like 40 bucks. i dont know if its true.
Old Apr 6, 2006 | 09:36 PM
Out of every
Default Re: (e gee two)
i gave you the diy why not try it? trust me knowing you did it on your own will be more satisfying then having someone else do it. i always dim = do it myself
Old Apr 6, 2006 | 10:04 PM
brokeHonda's Avatar
Take it to someone with a press, don't dremel/grind/shave out your hub just for satisfaction. It will take 30 minutes for the guy at a machine/tire shop to press out the hubs, knock out the old studs, slide in the new and repress the hubs. If you want to make it easier and possible cheaper take the hub assembly to the guy that way he doesn't have to pull it off your car.
Just my $0.02
Old Apr 6, 2006 | 10:28 PM
Luserkid's Avatar
Default Re: (brokeHonda)
I could do it, 20 a hub.
Old Apr 6, 2006 | 10:34 PM
lv6l's Avatar
where you located at.
Old Apr 6, 2006 | 10:57 PM
Luserkid's Avatar
Default Re: (lv6l)
PM or email me for more info.
Old Apr 6, 2006 | 11:14 PM
john666's Avatar
u got the studs already i will show u how to do it rite now if u want
Old Apr 6, 2006 | 11:27 PM
lv6l's Avatar
do you need any special tool to press out the hub john666?
Old Apr 6, 2006 | 11:47 PM
john666's Avatar
Default Re: (lv6l)
nah.
since ur fairly local i can show u in the quickness
Old Apr 6, 2006 | 11:51 PM
lv6l's Avatar
is it possible to show me by typing?
_Keith_
Aug 1, 2008 12:16 PM
x4thGenCafe
Jul 3, 2008 06:51 PM
Sifu
Suspension & Brakes
Apr 22, 2006 03:05 PM
ExCon
Jan 8, 2006 05:11 PM
articbluedc5
Feb 23, 2004 03:36 PM
