KG/MM springs for ITR (Spoon alternative)
Old Apr 4, 2002 | 07:07 PM
Spikey's Avatar
Default KG/MM springs for ITR (Spoon alternative)
For those of you who don't know, KG/MM is a major Japanese spring manufacturer, and one of the few who still manufacture their springs in Japan. KG/MM springs are famous for their quality and excellent ride characteristics. A major reason for that is that their springs are dual rate.
Anyways, just want to show that there are still other spring options other than SPOON.
Also, KG/MM springs are available for pretty much ALL Japanese cars, so if you have any friends with Toyota's, Mazda's, etc. you can let them know that they aren't limited to just TRD and H&R.
Old Apr 4, 2002 | 07:27 PM
kkim's Avatar
Default Re: KG/MM springs for ITR (Spikey)
how much does it lower the car by and what's the cost?
Old Apr 4, 2002 | 07:34 PM
Spikey's Avatar
Default Re: KG/MM springs for ITR (kkim)
front drop: 40mm
rear drop: 30mm
for pricing, check with R&D, IPS
CORRECTION:
front drop: 30mm
rear drop: 25mm
[Modified by Spikey, 4:42 AM 4/5/2002]
Old Apr 4, 2002 | 07:38 PM
AJ PwR's Avatar
Sorry wrong info.
DR SuperSports
Fronts lower 30mm and rear lower 25mm.
DR Racing
Front lower 35mm and rear lower 30mm
These are design for max. lowering without scraficing too much of the camber (tire wear).
Old Apr 4, 2002 | 07:39 PM
Spikey's Avatar
Default Re: KG/MM springs for ITR (AJ PwR)
sorry, i read the wrong line in the book
AJ PwR is right
Old Apr 4, 2002 | 08:23 PM
kkim's Avatar
what is the conversion of the spring rates to lbs/in?
Old Apr 4, 2002 | 08:31 PM
yoshi234's Avatar
I shoot brides
just multiply the spring rates by 55.9 to convert to lb/in
Old Apr 4, 2002 | 08:36 PM
Short_Shifter's Avatar
where can they be ordered from ?
Old Apr 4, 2002 | 08:42 PM
kkim's Avatar
Default Re: KG/MM springs for ITR (yoshi234)
thanks, yoshi
Old Apr 4, 2002 | 09:41 PM
AJR EJ8's Avatar
Default Re: KG/MM springs for ITR (Short_Shifter)
A&J racing carries them
Old Apr 4, 2002 | 10:28 PM
IVANITR's Avatar
Default Re: KG/MM springs for ITR (TYPE ONE Si)
For the ride height conversion just multipy the mm by .03937 to get the height in inches.
Someone throw out a prices for theses springs......
[Modified by IVANITR, 7:29 AM 4/5/2002]
Old Apr 4, 2002 | 11:37 PM
AJ PwR's Avatar
They are available at :
http://www.aj-racing.com http://www.ipsracing.com http://www.randdmotorsports.com
Old Apr 5, 2002 | 03:42 AM
Acura97GSR's Avatar
I don't have an itr but I have these springs on my gsr. I love them, and they are the best springs i've ever owned. (Yes I have had neuspeed and eibachs so far). They lower it perfectly, and the ride is great. I have them with some agx's set on 3 and I am very happy.
JT
Old Apr 5, 2002 | 04:59 AM
BlackAckeR's Avatar
http://www.aj-racing.com</a> http://www.ipsracing.com <A HREF="http://www.randdmotorsports.com" TARGET="_blank">http://www.randdmotorsports.com
Anyone have any othe sites for these? One of these doesn't list the products/prices, one doesn't seem to carry KG/MM, and the last doesn't seem to have the DC2R version!?...
Old Apr 5, 2002 | 06:03 AM
ITR764's Avatar
Default Re: KG/MM springs for ITR (BlackAckeR)
hmmmm 2.8k rear... doesn't that seem kind of low (lower than stock)??? what is stock again???
kg/mm also offers a damper kit sorta like the mugen low down's. looks like a nice kit.
[Modified by ITR764, 10:04 AM 4/5/2002]
Old Apr 5, 2002 | 06:15 AM
ITR00-816's Avatar
New User
Default Re: KG/MM springs for ITR (ITR764)
Stock rear is 140-246 I believe. That translates to 2.5k - 4.4k
[Modified by ITR00-816, 3:16 PM 4/5/2002]
Old Apr 5, 2002 | 10:40 AM
ITR764's Avatar
Default Re: KG/MM springs for ITR (ITR00-816)
ok then, that's not too bad. little stiffer than stock so that sounds like those would work real nice with the stock shocks. not too low or stiff. i'd like to lower a little to get some neg camber, lower center of gravity, and a tad stiffer wid out killing my shocks.
one more thing... are the rates posted 6.6/3.8 front 4.8/2.8 rear the progressive rates??? so it goes from 212.4-368.9 lbs front and 156.5-268.3 lbs rear.
[Modified by ITR764, 2:47 PM 4/5/2002]
Old Apr 5, 2002 | 10:51 AM
Mike M's Avatar
Founding Member
We carry them, Give us a call for price
Old Apr 5, 2002 | 12:12 PM
ITR00-816's Avatar
New User
Yes
Old Apr 5, 2002 | 12:15 PM
BoroDB8's Avatar
From: Waipahu, HI and Irvine, CA, best of both worlds, USA
kg/mm is the ****. i use them on my ae86. top quality!
Old Apr 6, 2002 | 10:40 AM
ITR0145's Avatar
New User
Default Re: KG/MM springs for ITR (boroDC2)
Old Apr 6, 2002 | 12:12 PM
typerev's Avatar
for those that have kg/mm in their ITR, have you ever noticed that the rear springs are awfully short? someone told me that they can actually be out of place between the perches when you go over a big bump
Old Apr 6, 2002 | 06:24 PM
R R's Avatar
R R
Default Re: KG/MM springs for ITR (typerev)
i have kg/mm on my R..ALOT better than the oem in my opinion...i will have the update of pics soon on my car...i believe the drop is 1.7 both front and rear..NO the tires do not rub!.......
and it helps b/c i just purchase 4 TOYO t1 tires.....all i can say is...DAMN!!!!
only one factor..now the front does need a camber kit..and yes u have to readjust the springs to get them back to the notch..
[Modified by R R, 7:27 PM 4/6/2002]
Old Apr 7, 2002 | 01:11 PM
AJ PwR's Avatar
Default Re: KG/MM springs for ITR (R R)
KGM - Best springs in Japan
batallic
Suspension & Brakes
Mar 6, 2009 07:03 AM
Wazup
Suspension & Brakes
Feb 6, 2006 10:46 PM
R.S.
Nov 6, 2003 06:08 AM
Phoenix_ITR
Apr 30, 2003 03:31 PM
itrsport.com
Jul 10, 2002 07:36 AM
