***Looking for an Alternate to Oil Squirter Plugs***
Old Apr 5, 2006 | 04:29 PM
BLKTeg94's Avatar
Default ***Looking for an Alternate to Oil Squirter Plugs***
Golden Eagle is backed up 3 weeks still on their oil squirter plugs. I'm wanting to get the motor done this week. Any other way I could do it? Someone said tapping it out and putting a brass screw in? Any reason for it to be brass and does it really need to be tapped out? Bottom end is already all together with the crank, rods and pistons in. Let me know.
Old Apr 5, 2006 | 04:41 PM
vaporboy12's Avatar
Default Re: ***Looking for an Alternate to Oil Squirter Plugs*** (BLKTeg94)
get a 1/8 ntp tap the go to your local speed shop that sells an fitting and buy the plugs there most places will have a 1/8ntp plug in stock if not jegs or summit will have them
Old Apr 5, 2006 | 04:42 PM
turbodohcsi's Avatar
leave the squirters in there, is always an alternative.
Old Apr 5, 2006 | 04:48 PM
vaporboy12's Avatar
Default Re: (turbodohcsi)
not if you are running forged internals i would just plug them and call it a day more oil pressure
Old Apr 5, 2006 | 04:51 PM
BLKTeg94's Avatar
I'm almost wondering if I could just go buy a bolt (10mm i think) And kinda make it look like the Golden eagles with a grinder? The be possible?? Then Chamfer it on the head so it'll tighten down? Does it have to be brass so it won't rust the motor?
Old Apr 5, 2006 | 05:12 PM
MrParks's Avatar
Default Re: (BLKTeg94)
pm'ed
Old Apr 5, 2006 | 05:47 PM
Muckman's Avatar
Moderator in Chief
Default Re: ***Looking for an Alternate to Oil Squirter Plugs*** (vaporboy12)
Whats the thread diameter and pitch on these? You could always weld or epoxy the holes shut...
Old Apr 5, 2006 | 05:55 PM
BLKTeg94's Avatar
Ya I'd like to know the Thread diameter and pitch. I'm gonna go see what Home Depot has to offer. If anyone knows tha'd be awesome.
Old Apr 5, 2006 | 06:22 PM
BLKTeg94's Avatar
bump to find someone that knows!! :D
Old Apr 5, 2006 | 06:26 PM
boosted94cx's Avatar
* B A N N E D *
15290-PR3-000
buy 1 of those and just check the threads...or buy 4 and close them off and then bolt them in
Old Apr 20, 2006 | 07:44 AM
lsturbohatch10's Avatar
Default Re: (boosted94cx)
i am putting a buddys b18c together and we were thinking of doing the same thing. we were going to use the squirters out of a b16 but they hit the crank.. how would you block off the pr3 bolts like you said above.^^
Old Apr 20, 2006 | 08:37 AM
B18C1CYA's Avatar
if the motor is totaly tore down , I would just use the 1/8" pipe tap and tap them bigger ,
Old Apr 20, 2006 | 08:50 AM
Default Re: ***Looking for an Alternate to Oil Squirter Plugs*** (B18C1CYA)
well the crank is in and torqued. but i can always take it out. if i tap it out i will just plug it with a 1/8 pipe plug right???
Old Apr 20, 2006 | 08:54 AM
HybridKOOP's Avatar
Default Re: ***Looking for an Alternate to Oil Squirter Plugs*** (lsturbohatch10)
Some race teams just bend them shut
Old Apr 20, 2006 | 09:00 AM
tony1's Avatar
Default Re: ***Looking for an Alternate to Oil Squirter Plugs*** (HybridKOOP)
Just weld the ends shut...
Old Apr 20, 2006 | 09:50 AM
JDM_Risa's Avatar
Default Re: ***Looking for an Alternate to Oil Squirter Plugs*** (tony1)
i am really gonna sound like a newbie...why would you want the to plug the oil squirter any reason behind this...thank you
Old Apr 20, 2006 | 10:22 AM
DJ Gurgla GSR's Avatar
Default Re: ***Looking for an Alternate to Oil Squirter Plugs*** (JDM_Risa)
although i don't agree with the decision to plug them....
Best idea i think is welding the tips of the squirters. seems like a very simple yet effective solution imo
Old Apr 20, 2006 | 11:28 AM
PSI-spec's Avatar
Default Re: ***Looking for an Alternate to Oil Squirter Plugs*** (DJ Gurgla GSR)
First off, u wont find those bolts at any hardware or home-depot store.
The bolt size is 8mm by 0.75 thread pitch only a metric bolt specialty warehouse would have it. Dont try to weld the holes shut or anything like that cause if your not a bad *** tig welder you'll crack or distort the alumunim.
Either tap an 1/8 npt hole or take an 1/4in aluminum spacer with 2 brass crush washers on each side.
Old Apr 20, 2006 | 11:37 AM
Default Re: ***Looking for an Alternate to Oil Squirter Plugs*** (PSI-spec)
Whats the problem with a small tack weld covering the tips of the squirters?
Old Apr 20, 2006 | 11:41 AM
Soccerking3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ Gurgla GSR &raquo;</TD></TR><TR><TD CLASS="quote">Whats the problem with a small tack weld covering the tips of the squirters?</TD></TR></TABLE>
nothing, he doesnt know what he is babbling about
Old Apr 20, 2006 | 11:53 AM
Default Re: ***Looking for an Alternate to Oil Squirter Plugs*** (Soccerking3000)
sounds like he is referring to tack welding the hole in the block where the squirters go. not welding the tips of the squirters themselves shut
Old Apr 20, 2006 | 12:38 PM
mike1114's Avatar
I had to plug them with some threaded plugs. I even tried grinding some of the bolt heads down but it would just not clear my LS crank in GSR motor.
Old Apr 20, 2006 | 12:39 PM
PSI-spec's Avatar
U could try tacking the hole shut but u run the risk of distorting the bolt. That bolt is hollow with a spring in it and it would probally leak and plus it's GHETTO.
Old Apr 20, 2006 | 12:44 PM
delacampos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Just weld the ends shut...</TD></TR></TABLE>
the way i've always done it. hell, GE even did this for me once when i had a block sleeved by them.
Old Apr 25, 2006 | 05:26 PM
Jason.H.'s Avatar
Default Re: ***Looking for an Alternate to Oil Squirter Plugs*** (delacampos)
I dont understand y u didnt just buy an ls block since u knew u were building a block and wanted to block the squirters off.??
GoLowDrew
Jun 19, 2012 09:00 PM
Midori Green
15
May 25, 2007 12:39 PM
cd5_2NR
Nov 26, 2005 05:52 AM
VtecDA9
Apr 5, 2004 11:17 AM
eastsidemags
Mar 22, 2002 01:22 PM
