need help with my v-tec wiring GSR (pics inside)
hey, i restored a gsr and put a b16 in it. i had to rewire the engine inorder to get it in the teg. so i bough a "gsr" wirng harness from some getho kid in the bronx. so the other day i started it up, went tfor a ride and fixed all the codes, i noticed i couldnt get code 22 to go away. so i checked my wiring. i tracked the vtec selenoid and v-tec oil pressure wiring and couldnt trace them to the plugs in the passenger shock tower( if thats where they are supposed to go?) and one of my plugs has two empty holes in it where on the other side which is the car plugs it seems i have the v-tec plugs (grn/yel) (blu/blk). here are some pics
you can clearly see that i have the v-te plugs on the engine harness
plug has two holes in it, on the other side the two wires that i belive are v-tec are located.
any input will be appriciated
v-tec maz
Apr 6, 2006 01:48 PM
jspresso
Nov 28, 2004 01:22 PM
