need help with my v-tec wiring GSR (pics inside)
hey, i restored a gsr and put a b16 in it. i had to rewire the engine inorder to get it in the teg. so i bough a "gsr" wirng harness from some getho kid in the bronx. so the other day i started it up, went tfor a ride and fixed all the codes, i noticed i couldnt get code 22 to go away. so i checked my wiring. i tracked the vtec selenoid and v-tec oil pressure wiring and couldnt trace them to the plugs in the passenger shock tower( if thats where they are supposed to go?) and one of my plugs has two empty holes in it where on the other side which is the car plugs it seems i have the v-tec plugs (grn/yel) (blu/blk). here are some pics
you can clearly see that i have the v-te plugs on the engine harness
plug has two holes in it, on the other side the two wires that i belive are v-tec are located.
any input will be appriciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">just cut em both off and vtec will work
thats what i'd do
yea dick, bump
thats what i'd do
</TD></TR></TABLE>yea dick, bump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kraig8 »</TD></TR><TR><TD CLASS="quote">is that the engine harness plug or the car harness plug?</TD></TR></TABLE>
i think car harness plug..
you might need to just run the vtec wires strait to the ecu and pin them in there. thats what i did since im still using all my ls wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorto85 »</TD></TR><TR><TD CLASS="quote">http://www.hondaswap.com/forum...41608</TD></TR></TABLE>
thanks, yea thats a good idea. because i need to wire my RPM wire straight to ecu too.
very good website
very good website
v-tec maz
Apr 6, 2006 01:48 PM
jspresso
Nov 28, 2004 01:22 PM
