Fuel pressure drop off after priming. AEM FPR, 1000cc's, 255pump
Old Apr 5, 2006 | 03:48 PM
dunkd's Avatar
Default Fuel pressure drop off after priming. AEM FPR, 1000cc's, 255pump
Walbro 255 pump
AEM Fuel Rail & FPR
Precision 1000cc injectors
Autolink liquid-filled guage on rail
stock everything else.
Got everything back together on my car from about 6 months of sitting and after I prime the fuel pump the pressure drops right down to zero. If I start the car it is fine and holds a steady pressure @ 44psi. I drove the car for about fifty miles and it runs ok.
No matter how many times I prime the pump the pressure will drop right back to zero after the pump turns off. There are no external fuel leaks anywhere.
Why is it doing this? Bad AEM FPR? Last year it was fine.
Old Apr 5, 2006 | 03:57 PM
adictionbass's Avatar
Default Re: Fuel pressure drop off after priming. AEM FPR, 1000cc's, 255pump (dunkd)
when my car was running *cough* *cough* and i turned the key to on, the pressure would go up, and slowly fall back to 0 after a minute or so. This is with a brand new aeromotive FPR
PS check my thread
Old Apr 5, 2006 | 04:02 PM
dunkd's Avatar
yah mine doesnt hold it for very long at all. I have just enough time to turn the key and look around my hood too see the needle drop.
Old Apr 5, 2006 | 04:17 PM
turbo*s2k's Avatar
Mine does the samething. Never considered it to be a problem. I would only worry if it dropped while the car was on or under boost!
Old Apr 5, 2006 | 04:22 PM
dunkd's Avatar
yah we'll find out if its really an issue when it goes on the dyno next week. Im bring a spare FPR just in case.
Old Apr 5, 2006 | 04:34 PM
philipwight's Avatar
Default Re: (dunkd)
i dont think that the walbro pump holds the residual pressure the same as a stock fuel pump. the check valve that does that may be too much of a restriction.
Old Apr 6, 2006 | 02:44 AM
DaveF's Avatar
Default Re: (philipwight)
my fp also drops off like a brick. after shutting the car down. this is with a weldon regulator. it also did the same with my aeromotive regulator. im also using the walbro HP pump.
Old Apr 6, 2006 | 04:16 AM
2point2's Avatar
It's the fuel backfeeding back through the walbro pump. mine does this too.. so it better be ok
I think philipwight was on to something... It's sort of obvious by the size (and someone correct me if I'm wrong) but the stock and walbro are two totaly different style pumps. So I wouldnt compare the way the stock one holds pressure vs the walbro.
If my teacher spoke english I would have been able to describe the difference between the two.
Old Apr 6, 2006 | 06:47 AM
RTW DC2R's Avatar
Im running the walbro 255, aem rail, and b&m gauge and fpr, and mine DOES NOT drop off like a brick. I will be double checking this once the car is back together.
Old Apr 6, 2006 | 08:29 AM
littlebluecrx's Avatar
it's s o.k., as long as she holds when the pump is running, stays set were you put it, and doesnt drop off under boost. All is working well. The factory regulator, and pump are meant to hold pressure, so they start on the 1st crank.
Old Apr 6, 2006 | 07:47 PM
dunkd's Avatar
cool thanks for the info guys... so this explains why I always have to let the fuel pump prime before I start it.
eg:R
Dec 31, 2011 11:42 AM
eg:R
Jul 9, 2011 09:28 PM
si90rex
15
May 18, 2010 05:03 PM
superturboprelude
Jul 10, 2007 06:04 PM
digital sol
Jun 23, 2006 05:27 PM
