Gas mileage
Check your ignition system
Check your spark plugs (especially the gap)
Check your CAT
Check your tire pressure
Check your piston compression
Check your trunk, if there is lots of junk that you don’t need throw them away
Change your driving habits (don’t try to show off too much) this will save some gas
Check your CAT
DANG! I drive a '91 Accord EX and I'm doing good to get over 400 miles/tank. Of course I do drive either 75 or in stop and go traffic. Based on my experience I wouldn't try for 500, but you are already doing better than me.
the only way you are going to get 500 out of a tank is by to get over 35mpg on 14 gals of fuel that is not possible in these cars with any type of city driving involved
These cars are rated 24/30 and I'll give you my 94 car stats whick is rated at 23-25 and 29-31
around town
I get around 24-25 and on the hwy I get 32-34.XXX
around town
I'm guessing he is doing mostly highway driving because of the 32mpg he is already getting.
There are ways to increase the fuel milage. All of them I can think of require aftermarket mods. I haven't had near enough caffiene this morning so I couldn't tell you names.
The newest one I have seen I can't even remember how it works, except that it was pushing 2 or 3 more MPG on the Chrysler Sebrings. The other one has been around years and it adds a mist of water to the fuel before it gets to the engine, thus burning a little water instead of fuel and lowering the fuel usage. Although with the water one you have to fill the water tank occasionally.
I barely get 230 up to 1/4 of a tank. must be nice to get 400. hopefully i may be able to get it closer to 300 after i am done with my 5spd swap and tuning.
Instead of looking at how many miles you get per tank, pay attention to how many miles you actually get per gallon.
Next time you fill up... reset your trip odometer (or write down the mileage). Let it get low, fill up again, divide miles traveled by number of gallons you just put in. For a better average, do this a few times and keep a cumulative mileage.
I get 28 in town and 34 highway doing 75-80 in my 98 lx 4dr 5speed.
Would it be worth while to add an intake to get better mileage. I also have a dc coated header from my 94 ex laying around If it fit would it be worth my while.
Basically what I'm asking is if anyone has done any mods and noticed an improvement in mileage?
i put cai on my 94 LX. if u keep ur foot out or the floor it helps gas alittle. light crank pulley helped on my 89 prelude si befor i slung a rod. and a cleen filter and good oil(synthetic) will help too
That's bull on the fuel pump going if you let it go empty a lot, I've had a 93 since it had 36,000 on it, it's now got 334,000 miles and I let it go till the light comes on and then try and push it as far as I can, original fuel pump still in it. more times than not the light was on it seemed.
Not sure about your tank but my 93 has a 17 gallon tank in it so technically you'd need to get 29 MPG to get 500 miles on the tank, it's dooable but like they said you gotta drive like a granny and do 55 on the highways. but you can do it.
I have an 05 Civic now and can do 500 miles on a tank and it's only a 13.2 gallon tank, the Accord was a bit quicker but with gas as pricey as it is, I'm lovin the civic. Plus only 37,000 on it instead of the 334,000 on the Accord. I love my honda's
Thats not bull, a company I used to work for did that with their company vans...and guess what those things were in the garage for getting repaired at least once a year?
anyways...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by briq4 »</TD></TR><TR><TD CLASS="quote">
i drive a '95 accord LX and it gets about 36 miles to the gallon... so what now!! </TD></TR></TABLE>
How the hell are you getting 36mpg?!! Even on the Highway! I have the same car (with four banger) and the best I ever got was like 25...
anyways...
'91 EX coupe, 249,500 miles. Recently got about 26, regularly cruising @ 80mph on the freeway and usually semi-hard acceleration at times. I'm about to get some more stuff done to it so maybe I can get just a bit better mileage soon.
tz12789
10
Sep 12, 2008 11:05 AM
ex_techniques206
Apr 20, 2005 02:59 PM
