turbo LS coupe not starting
here's an overview of what happend and what i did..
specs
98 civic coupe w/
b18b
tial 38mm wastegate 9psi spring
t3/t4
blox manifold
cartech fmu 12:1 ( shitty i know but kit came with odb1 injectors and i dont have hondata or uberdata yes)
missing link
golden eagle vaccum manifold box
the car ran fine for 1day pulled hard and everything, but i took it out one last time for a testdrive with my cousin and when i returned home i let it idel to roll into my driveway and thats when it died..
oil was all over the battery area the fuse box but not alot it was just thin layerd the pcv valve was broke i broke it on accident but it poped back together so i just left it like that.. but it was broken in half when i poped that hood that time.
the car didn't want to start. i checked fuses, spark,fuel, and timing.. so then i took the head off thinking the pistons would have some big holes in them but they where fine and so was the head.. then i took the head apart to find everything in working order.. BUT i did find out that my ls block has b16 si pistons in it.. the block and sleevs looked perfect aswell. although i think that it would have been pretty high compression i think for a turbo motor
so i put a new headgasket on rechecked the whole wiring harness redid timing but still no starting it.. also a mist of oil comes out of the breather hole where all the oil shot out of it before.. but its just a mist of it im gonna do a compression test tonite.. the only thing else i can think of is the rings broke or melted or somthing ?
anyone have an input
this was my dailey and the turbo was supposed to be a 1 nite install but this is killin me
specs
98 civic coupe w/
b18b
t3/t4
blox manifold
missing link
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_serious »</TD></TR><TR><TD CLASS="quote">i did i bought new headgasket and pcv valve</TD></TR></TABLE>
same problem still? after you changed those out?
since your motor was apart.. you should have taken your bottom end apart.. im pretty sure that you have no compression because you blew a piston or 2, if you run your car hard w/o forged pistons you'll end up melting u're stock ones.. take your head off, take your oil pan off, and take your main caps, and the bottom rod ones, and pop your pistons out through the top.. almost positive your going to find holes in the sides of your pistons along with melted rings to accompany them.
More than likely if you were leaking oil and losing oil pressure you have fried your rings or pistons like tomu06 said so take the pistons out and go from there. While they are out you mine as well change them to a lower compression or get a thicker headgasket.
opening post!
opening post!
he didnt take the pistons out though, just looked at the tops of them.. and you can't tell by the surface if they have huge holes on the sides of them.. but if there was fried piston rings/melted piston, the access usually goes to the oil pan, and you will see a few chunks of goodies in there.
EXACTLY what my pistons looked like in my LS turbo setup.. I was stupid and didn't get it tuned and just ran an FMU like you did... I'd put my money on not enough fuel being the problem
