my car keeps overheating :(
well i put in eg radiator and was runnin a flow plate instead of a thermo and it wouldnt slow the water down enough but i have changed that no its over heading again i dont know what the deal is it seems like im osing water but i cant figure out where ive checked everwhere and no leaks not even around the water pump
its an 90 ls motor i couldnt tell how many miles r on it all i know is the pump worked in the car i took it out of so what do yall think
Why the hell don't u have a thermostat? That is probably one of the main reasons along with you needing a new headgasket, deck on both block and head and possibly a new water pump would fix this. Hopefully ur head isn't cracked or warped.
was the radiator you got in good shape? it may need to be flushed out, might have some build up
also you can still have a blown HG and clean oil, if the smoke is white-ish blue, i'd say your burning both coolant and oil but thats just my .02
well could it be a bad ratiator cap cause after i posted all this i went out side and tinkered on it and let it sit and idle and the coolant is running into the overflow and boiling out the tank can this be my problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipkc »</TD></TR><TR><TD CLASS="quote">Why would you even drive around with a blown HG and risk ruining the car even MORE. Like come on, save up for $150 and get a decent one. Don't be cheap.</TD></TR></TABLE>
a oem headgasket does not cost $150, its $40 for the gasket
or you can buy the gasket kit which comes with every gasket needed for the head for right at about $100
dont bother buying something else, just about everyone will agree oem honda gaskets are best, and if you dont have many mods there isnt any point in spending the extra cash for a diffrent one
any auto parts store, or call a dealer and have them ship it
thats half the work is tracking down the parts sometimes, i've been looking for a damn main relay for a week and a half and finaly found one but i had to get it shipped to me from the store that had it cause they were over 300 miles away
hey man i would say that it sounds like to me that you do have a blown head gasket. i would go ahead and replace it and hope you did not do any damage to the head. but if it is your only way around i would by some liquid glass and put it into the radiator to seal the weak head gasket for now until you can get them parts. i dont know how long that **** will hold up dough but it is worth a try
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lloydadvance »</TD></TR><TR><TD CLASS="quote">hey man i would say that it sounds like to me that you do have a blown head gasket. i would go ahead and replace it and hope you did not do any damage to the head. but if it is your only way around i would by some liquid glass and put it into the radiator to seal the weak head gasket for now until you can get them parts. i dont know how long that **** will hold up dough but it is worth a try</TD></TR></TABLE>
untill it clogs your coolant passages and blows your motor
never put crap like that in your car, a HG is $40 and the studs are like $2 a piece i think, i dont remember the price for those.. driveing with it like that for a little while wont kill it do anymore damage then is already done unless you drive with the needle pegged, i drove with a bad HG for almost a year, sold it to my buddy, and he drove it for a year and a half before it blew, it just ot a little hot after getting off the freeway or while idleing sometimes
you'll wanna get your head and block checked anyway since its been overheating to check that both are straight and not warped
SPORT INJECTION
Aug 25, 2003 12:15 PM
wignersfriend
Dec 26, 2002 07:11 PM
