Civic Sir axle vs Integra axle
Old Apr 5, 2006 | 11:48 AM
wildman117's Avatar
Default Civic Sir axle vs Integra axle
I have a honda civic sir. My passanger side axle is clicking. Piston ring offers lifetime warrenty on axles, but they don't have a listing for the Sir. They only have the civic Si and base models. Is there another shaft from a honda that is more common which I could use in their computer to get the right shaft?
Old Apr 5, 2006 | 01:25 PM
sol lovin's Avatar
Default Re: Civic Sir axle vs Integra axle (wildman117)
sir is that dual cam stock? if it is, any bseries axles will work depending what year it is. if its single get single cam axles for your year.
for example you have a 92-00 civic with a b16 swap you use b-series axles from a 94-up integ, 99-00 si civic
if you have an ef it might be different with the DAs too.
Old Apr 5, 2006 | 01:54 PM
wildman117's Avatar
The car came stock with a b16. Piston ring has different part numbers for GSR axles and other integra axles. Which is the right one to use?
Old Apr 5, 2006 | 03:31 PM
egsleepercivic's Avatar
only difference between 94-up B series axles is abs or no abs. if you don't have abs you can get either. if you have abs you have to get abs axles. oh JDM r's and CRV's have 36mm axles while all others are 32mm. hope this helps good luck. are you in canada?
Old Apr 5, 2006 | 08:33 PM
wildman117's Avatar
yea I am from canada
DC206R
Mar 27, 2011 06:55 AM
aojtin
Apr 16, 2009 05:20 PM
bratch
Oct 6, 2008 10:56 AM
slow_db7
Apr 11, 2008 12:37 AM
ncrx1
Dec 13, 2001 05:52 PM
