TODA Spec C's daily driving???????
Old Apr 4, 2002 | 06:08 PM
MOTOR R's Avatar
Default TODA Spec C's daily driving???????
is it safe or not to daily drive on the spec C's........
Old Apr 4, 2002 | 06:43 PM
zijiejijeijrkjk's Avatar
Default Re: TODA Spec C's daily driving??????? (MOTOR R)
i hope someone can answer also.
Old Apr 4, 2002 | 06:50 PM
Pinhead's Avatar
New User
Default Re: TODA Spec C's daily driving??????? (elements)
any cam is streetable...well with the exception of skunk stage 3
Old Apr 4, 2002 | 06:52 PM
nfn15037's Avatar
Default Re: TODA Spec C's daily driving??????? (Pinhead)
Like Pinhead said, ANY cam is streetable, its just what you are willing to deal with, even Skunk2 III
Old Apr 4, 2002 | 07:30 PM
GokuSSJ4's Avatar
Default Re: TODA Spec C's daily driving??????? (nfn15037)
just requires lots of tunning and also making sure that you are running the right valvetrain .
and some required valve adjustment so often
Old Apr 4, 2002 | 07:31 PM
azn98R's Avatar
From what I hear it's not too smooth in the streets, cause it like to be driven hard in order to run smoothly. "Too radicle for daily driver", so I've been told.
Old Apr 4, 2002 | 07:46 PM
TypeR0149's Avatar
Default Re: TODA Spec C's daily driving??????? (azn98R)
DUDE DONT DO IT. AFTER 500 MILES your motor will blow up.
Old Apr 4, 2002 | 07:48 PM
Pinhead's Avatar
New User
Default Re: TODA Spec C's daily driving??????? (Vegeta)
LOL
Old Apr 4, 2002 | 08:32 PM
TRuST's Avatar
I know that a couple of people here on this board are driving around on those daily. What color is your ITR ? I wonder if I have seen you before, becasue I'm also from the Beach.
Old Apr 4, 2002 | 09:14 PM
Mr. Softee's Avatar
Default Re: TODA Spec C's daily driving??????? (TRuST)
mang f that shiz.
Old Apr 4, 2002 | 09:22 PM
IntegD's Avatar
New User
Default Re: TODA Spec C's daily driving??????? (94goldjungsr)
From what I read, pretty much every cam is streetable with the right tuning. Maybe the VTEC killers might be the only ones I would be scared of..lol
Old Apr 4, 2002 | 09:29 PM
TypeR0149's Avatar
Default Re: TODA Spec C's daily driving??????? (IntegD)
I tink dat da skunk stage 3's be a wee bit extreme for da street sonny boy
Old Apr 4, 2002 | 09:59 PM
FSTASNTZ's Avatar
Spec Cs are fine for the street. In August it will be 2 years that I have been driving with them every day...
Jason
Old Apr 4, 2002 | 10:04 PM
Pinhead's Avatar
New User
Default Re: TODA Spec C's daily driving??????? (FSTASNTZ)
what'd dyno at and what other mods you got to get you into the 13.4 mark?? any weight reduction?
Old Apr 5, 2002 | 12:46 AM
RC211V's Avatar
screw it go with the vtec killers
Old Apr 5, 2002 | 02:47 AM
nfn15037's Avatar
Theyre not any worse than Spec Cs. Theyre Magically Delicious
Old Apr 5, 2002 | 04:49 AM
Dipshit Dan's Avatar
C's are just as streetable as B's. They are fine if you can deal with the slightly lumpier idle.
Old Apr 5, 2002 | 04:52 AM
tecnic1's Avatar
It depends on what color your car is...FBP ITR's can beat topfuel dragsters and still be daily driveable. PY ITR's spontaniously explode....and yeah, what color is your car?
Old Apr 5, 2002 | 05:07 AM
FSTASNTZ's Avatar
Default Re: TODA Spec C's daily driving??????? (God)
If you tune it just right, you can get rid of that lump for the most part. Mine idles more deep than it does lumpy...
Jason
Old Apr 5, 2002 | 07:45 AM
MOTOR R's Avatar
im from VA beach.....I drive a Black Wingless R with black 15' Slipstreams
Old Apr 5, 2002 | 08:04 AM
TRuST's Avatar
I'll try to say if I see you.
Old Apr 5, 2002 | 08:05 AM
98TypeR's Avatar
yah, the c's and b's have hte same primary lobes so they are equally as streetable. If you tune right, you won't get a lumpy idle. All you'll get is alot of valve noise
Old Apr 5, 2002 | 09:17 AM
sgT's Avatar
sgT
Default Re: TODA Spec C's daily driving??????? (98TypeR)
IS IT SAFE TO DAILY DRIVE ON TIRES MADE OF RUBBER?????????????
WHAT ABOUT TIRES MADE OF RUBBER BUT FILLED WITH AIR??????
ARE THOSE SAFE??????
Old Apr 5, 2002 | 09:20 AM
sackdz's Avatar
Default Re: TODA Spec C's daily driving??????? (sgT)
I don't think he meant "safe" as in safety. Relax, you're hurting my eyes.
[Modified by sackdz, 1:23 PM 4/5/2002]
Old Apr 5, 2002 | 09:22 AM
GokuSSJ4's Avatar
Default Re: TODA Spec C's daily driving??????? (tecnic1)
friend of mine is also trying the stage 3 from skunk , and well the only thing that he did was put 2 headgaskets to make sure for the clearance and run skunk valvetrain on a b16 with ctr pistos , so we will see what happens .the gains and also hopefull he doesnt blow his motor !
[Modified by Spoon1, 6:23 PM 4/5/2002]
