How To Tell If You Need A New Ignition Switch or Ignition Cylinder?
Old Apr 5, 2006 | 10:59 AM
b18cEK's Avatar
Default How To Tell If You Need A New Ignition Switch or Ignition Cylinder?
As the title states.
Right now my ignition will move to ACC 1, but not ACC 2. Which means I cannot start my car.
Old Apr 5, 2006 | 07:43 PM
b18cEK's Avatar
Default Re: How To Tell If You Need A New Ignition Switch or Ignition Cylinder? (civic-rmod)
help!!!
Old Apr 5, 2006 | 08:52 PM
ccjustin's Avatar
if you put the key into the ignition it physically won't turn? I'd say check the key, then the ignition cylinder
Old Apr 5, 2006 | 09:01 PM
b18cEK's Avatar
Default Re: (ccjustin)
yeah it will move into the first position where the radio will work but not the 2nd position
Old Apr 5, 2006 | 09:06 PM
b18cEK's Avatar
the key moves into the 1st position, but not the 2nd.
Old Apr 5, 2006 | 09:23 PM
ccjustin's Avatar
don't know, jiggle the steering wheel while you do it. otherwise pull the steering column off, take the cap off the back off the ign cylinder and start it with a screwdriver, then just put the key to the 1st pos. to unlock the column.. I mean if you're stuck
Old Apr 6, 2006 | 05:43 AM
b18cEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccjustin &raquo;</TD></TR><TR><TD CLASS="quote">don't know, jiggle the steering wheel while you do it. otherwise pull the steering column off, take the cap off the back off the ign cylinder and start it with a screwdriver, then just put the key to the 1st pos. to unlock the column.. I mean if you're stuck</TD></TR></TABLE>
huh, i can start the car with a screwdriver by taking off the cap?
Old Apr 6, 2006 | 05:49 AM
dgmorr's Avatar
Default Re: (civic-rmod)
Yeah, just take off the cylinder. Just put a flat head in there and turn.
Old Apr 6, 2006 | 06:02 AM
b18cEK's Avatar
Default Re: (dgmorr)
what exactly an I taking off?
Old Apr 6, 2006 | 06:17 AM
dgmorr's Avatar
You have to take everything to the right of the hub off. I've never done it, but I had my stolen car recovered this week and it was off. This is the only reason I know how it's done
Old Apr 6, 2006 | 06:23 AM
egredspools's Avatar
On the left side of the cylinder opposite of the key hole there is a plastic white cap and there should be 2 screws take those off the cap comes off and there is a slit in the cap stick and objectn that is i guess like a jey of flat head and turn and the car should turn up......like the guy said myn was stolen to and myn was apart and hanging thats how i know and i was a tech so eh....
loki2010
Dec 30, 2010 07:18 AM
1sikhatch
Apr 8, 2010 08:58 AM
soon2bdropped
Oct 21, 2007 12:32 AM
VTECdTypS
23
Jan 20, 2005 02:25 PM
DerangedEG
Nov 17, 2004 02:59 PM
