Dangit! what's the brake bleed order again?
search doesn't work.... I want to make sure it's driver front, passenger front, passenger rear, then driver rear..... is this corrent? Or do I have it wrong?
1) Rear Right
2) Front Left
3) Rear Left
4) Front Right
WHAT?!??!
Owen the soyboy just check his manual and his says passenger front, driver front, driver rear, passenger rear.....
Did the bleed orders change from year to year? I have a 1994 GSR sedan. What year is your helms?
In the Helm's manual, it says the order is:
1) Rear Right
2) Front Left
3) Rear Left
4) Front Right
I concur.
1) Rear Right
2) Front Left
3) Rear Left
4) Front Right
I concur.
WHAT?!??!
Could this be a major screw-up?
I think the lesson here is that it probably doesn't matter all that much...
i thought it was front drv, front pass, rear pass, rear drv. I could be wrong. I dont have my manual with me.
maybe the order is different from 94-97 to 98+ because I just called the Acura dealer and they said rear right, front left, rear left, front right..... they said this was the order for a 94 GSR.....
No matter what the car, generally it should be working from the farthest wheel from the master cylinder to the closest. I just did this for my teg and it even had that specified in the shop manual for my car. You could probably get away with a different order but going from furthest to closest to the master cylinder reduces the chances of air being introduced to the system.
For my car it was...
Right Back
Left Back
Right Front
Left Front
Right Back
Left Back
Right Front
Left Front
i had to bleed my brakes 4 times to get it correct, recently. The correct order is Passenger Rear, Drivers Front, Drivers Rear, Passengers front. I own a 1995 Acura Integra LS
alex_s817
Jul 3, 2006 08:51 AM
s73
11
Jan 24, 2005 08:42 AM
