Baffling a catch can?
Old Apr 5, 2006 | 08:28 AM
Race Egr's Avatar
Default Baffling a catch can?
Im thinkin of fabin up some catch cans ,but Im wonder how to properly baffle them? Any suggestions would be great
Old Apr 5, 2006 | 07:50 PM
Bailhatch's Avatar
Default Re: Baffling a catch can? (NAPIER)
I'm doing a vertical, round one and I plan on having a flat vertical divider between the vacuum side and the crankcase side. I think i will have it go about 3/4 of the way down and use loose stainless wool on both sides.
I'm defiantly going to have a drain that is easy to use too, because if this thing fills up too far I think there could be some nasty issues depending on how good the vac source is.
Old Apr 5, 2006 | 11:28 PM
Turbo-charged's Avatar
stick some double cheezeburgers in there
Old Apr 6, 2006 | 07:50 AM
Race Egr's Avatar
Default Re: Baffling a catch can? (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">stick some double cheezeburgers in there</TD></TR></TABLE>
you and your damn cheezeburgers I think thats why you alaways have gas
Old Apr 6, 2006 | 09:15 AM
FERIOkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER &raquo;</TD></TR><TR><TD CLASS="quote">
you and your damn cheezeburgers I think thats why you alaways have gas </TD></TR></TABLE>
now thats just nasty
I used steel wool for mine and put a drain plug in the bottom of it with a lock washer, been working fine for months
Old Apr 6, 2006 | 10:29 AM
kommon_sense's Avatar
Default Re: Baffling a catch can? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">I'm doing a vertical, round one and I plan on having a flat vertical divider between the vacuum side and the crankcase side. I think i will have it go about 3/4 of the way down and use loose stainless wool on both sides.</TD></TR></TABLE>
From what I've read it is best to use something like a few feet of chain link instead of stainless wool. Problem is if a bit of the wool were to break off, it could be sucked back into the engine depending on how you plumb your catch can.
vtec_lude
Welding / Fabrication
16
Sep 13, 2007 10:28 PM
Vtec4life1
Nov 13, 2006 03:57 PM
sumo
Jul 30, 2006 09:15 PM
@irborne
17
Nov 6, 2005 04:32 PM
jDMJeRk
Jul 28, 2004 09:33 PM
