help with hub bore size & bolt pattern for aftermarket wheels
Old Apr 5, 2006 | 08:09 AM
anewbreedx008x's Avatar
Default help with hub bore size & bolt pattern for aftermarket wheels
i am trying to get some new wheels and tires and im lookin at the 17'' rota subzeros they are 17x7.5 bolt patteren:5x114.3 offset:45 hub bore:73
do i need hub rings or? hellpp
205/45/17 bf goodrich KDW's going on them
Old Apr 5, 2006 | 10:07 AM
silver comet's Avatar
Default Re: help with hub bore size & bolt pattern for aftermarket wheels (anewbreedx008x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anewbreedx008x &raquo;</TD></TR><TR><TD CLASS="quote">i am trying to get some new wheels and tires and im lookin at the 17'' rota subzeros they are 17x7.5 bolt patteren:5x114.3 offset:45 hub bore:73
205/45/17 bf goodrich KDW's going on them </TD></TR></TABLE>
not really familiar with the hub bore but 17x7.5 bolt patteren:5x114.3 offset:45 should be fine
Old Apr 5, 2006 | 10:51 AM
jspec rsx's Avatar
Yes the hub on the rsx are 64.1 you will need hub rings. if you want your wheels to be hubcentric
Old Apr 5, 2006 | 02:01 PM
so the hub on the rsx is 64.1 and the rim is 73...so what size hub ring do i need? so that means the hub is smaller than the bore right?
Old Apr 5, 2006 | 02:22 PM
PrevWon's Avatar
Silver Comet i like your avatar
Old Apr 5, 2006 | 04:12 PM
BarracksSi's Avatar
Default Re: (anewbreedx008x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anewbreedx008x &raquo;</TD></TR><TR><TD CLASS="quote">so the hub on the rsx is 64.1 and the rim is 73...so what size hub ring do i need? so that means the hub is smaller than the bore right?</TD></TR></TABLE>
Bingo --
The ring size would be 64.1 x 73 -- Discount Tire Direct sells them for about 20 bucks, and theirs should be a light purple/magenta color. I've got them under my Circuit 10's.
Old Apr 5, 2006 | 05:25 PM
awesome, so the wheels will be fine with the rings, what do the rings accually do, i mean im no dumbass ive put aftermarket rims on cars be4 but ive never really had to be so precise, but i do want the car to ride as nice as it does now, i can roll at 85mph and its smooth and quiet. i like it
Old Apr 6, 2006 | 08:40 AM
krystar's Avatar
205/45/17 tires would throw your speedometer off by 2.5%
when your speedo reads 60mph, you are actually traveling 58.5mph.
the proper size for 2002-2004 RSX's for 17" rim is 225/45/17
Old Apr 6, 2006 | 12:40 PM
BarracksSi's Avatar
Two good sites that you need to know:
http://www.miata.net/garage/tirecalc.html (easiest tire size calculator I've seen)
http://1010tires.com/tech.asp?...rbore
krystar is correct, that tire size of yours is a bit on the small side. The good thing is that you won't be accidentally speeding as much as you'd think from a cop's point of view. Using the calculator in the first link, you can find several sizes that would also work on your 17's.
AznBlueBoy
Mar 24, 2011 12:00 PM
Diego Dangers.
May 27, 2008 04:29 PM
BIGTUNA
Mar 10, 2006 06:38 AM
Jaydeep
Jun 24, 2005 12:48 PM
CC2
Apr 16, 2004 01:01 PM
