d16z6 engine harness into crx dx
Old Apr 5, 2006 | 07:13 AM
wfocrx's Avatar
Default d16z6 engine harness into crx dx
I was wondering if was possible to just swap out engine harnesses if you were to buy a d16z6 complete engine with all sensors and IM, fuel, rail, injectors and ecu.
Old Apr 5, 2006 | 07:19 AM
wfocrx's Avatar
just realized this questin was asked a little while ago.
but...
nobody gave a real answer as to if it would work.
Old Apr 7, 2006 | 12:39 PM
wfocrx's Avatar
anybody
Old Apr 7, 2006 | 05:33 PM
Default Re: d16z6 engine harness into crx dx (wfocrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if was possible to just swap out engine harnesses if you were to buy a d16z6 complete engine with all sensors and IM, fuel, rail, injectors and ecu.</TD></TR></TABLE>
no totally different sockets and plug shapes
Old Apr 7, 2006 | 05:35 PM
exsinnovation's Avatar
NO. thanks for playing try again
Old Apr 7, 2006 | 10:11 PM
wfocrx's Avatar
pardon my ignorance.
I haven't really looked at everything.
but I figured a d16z6 complete motor with sensors, d16z6 engine harness and d16z6 ecu it would all work together.
Old Apr 7, 2006 | 11:42 PM
nope
i would make a ******* remark about it but its like 12 and I have a kid
nah man its good that u have the complete harness cuz ur gonna hevt o cit some **** off the z6 harness to wire it up to your dx harness
i.e. injectors, vtakk plugs, dizzy plugs
go to rywire and by there obd0-1 conversion harness.
Keep the 4 wire o2 sensor if its still attatched to the z6 harness
just get the p28 pinout and work at it for a week or so and u'll be super jdm fast hittin vtakk all the way down the highway
vroom vroom
Old Apr 18, 2006 | 09:46 PM
wfocrx's Avatar
I got the p28 ecu, d16z6 harness and d15b auto harness. What all do I need to get my d16z6 running. Is their any place online that will tell me? I would really like make this project as much DIY as possible. Should I just buy the complete dx to obd1 vtec harness from rywire of just get like the obd-0 to obd1 harness?
Old Apr 18, 2006 | 10:04 PM
Khmi's Avatar
Default Re: (wfocrx)
For my z6 swap i went to rywire, ran me about $300 including the jumper harness. More than i paid for the motor, but when i got it back it was just plug and play.
Old Apr 18, 2006 | 10:22 PM
wfocrx's Avatar
so it went in smoothly?
did you go dx to d16z6?
I have to send in both harness's correct? how was the turnaround time?
thanks.
Old Apr 19, 2006 | 12:59 AM
Rywire's Avatar
Yes, send both, turnaround is like 1-3days in my hands, and priority 2-3 days back. Yes it is expensive, but think of it this way... Its plug and play, and will look factory. I can give tech on the swap, and I have done this conversion like 1,000 times, and I basically NEVER screw up, lol.
Ryan
Old Apr 20, 2006 | 03:39 PM
Khmi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx &raquo;</TD></TR><TR><TD CLASS="quote">so it went in smoothly?
thanks.</TD></TR></TABLE>
Everything went good, except on my part. I gave him my, dx harness from my parts car (DX with a ZC in it, because my si harness was chopped up), but forgot to mention it to him. When i had got home the plugs didnt match up, called him and told him what happend, and just traded the harness he made, and gave him a my old si si harness. Ryan made it work. I live in the Bay area so i just drove down, the only thing i had to do was extend a wires for 2 plugs the MAP sensor, and i think TPS. No biggie.
Old Apr 20, 2006 | 11:22 PM
Rywire's Avatar
Default Re: (Khmi)
The wires that you have to extend are the Map, and the Purge solenoid(if you decide to use the engine mounted sensors). They are located on the firewall harness(not engine), and need to reach the engine mounted sensors.
Ryan
Old Apr 21, 2006 | 12:26 PM
ThriLlz_'s Avatar
Default Re: (droppedcrxsi)
so basically if i buy the dx mpfi obd1 harness [$300] from rywire with the plug n play option and completing the swap with the d16z6 motor i changed from dpfi to mpfi and ob0 to obd1? that would be everything i need OTHER than the full z6 motor and ecu?
ill be buying the d16z6 in a month or so, so could you guys name everything i would be needing to come with the engine? thanks.
Old Apr 21, 2006 | 12:28 PM
Rywire's Avatar
Default Re: (ThriLlz_)
yop thats all your wiring covered
Old Apr 21, 2006 | 12:33 PM
ThriLlz_'s Avatar
sorry for asking another question but could you guys tell me what kind of car to get a p28 ecu out of and also could you name everything i would need to come with the d16z6 motor? thanks again
Old Apr 21, 2006 | 05:56 PM
Rywire's Avatar
ill pm ya
Old Apr 21, 2006 | 06:39 PM
cyph3r's Avatar
we do the dx to mpfi-vtec-obd1 conversions cheaper with fast turn arounds.
pm if interested
Old Apr 22, 2006 | 07:35 PM
Khmi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThriLlz_ &raquo;</TD></TR><TR><TD CLASS="quote">sorry for asking another question but could you guys tell me what kind of car to get a p28 ecu out of and also could you name everything i would need to come with the d16z6 motor? thanks again</TD></TR></TABLE>
You can get a p28 out of a 92-95 civic Si, or Ex. Look to spend around $80-$175, look around because the P28 is a very desirable ECU. Make sure the ECU is for a 5spd.
For parts this site has good info on the swap http://www.thezcr.com/html/odbiconversion.php
Old Apr 23, 2006 | 09:16 PM
ThriLlz_'s Avatar
Default Re: (Khmi)
wow thats a really clear guide. thanks alot!
justa4banger
Nov 10, 2008 07:43 PM
EpicTuning
Northeast (Sales)
Jan 29, 2008 09:53 AM
