For all you nitrous and plug reading experts please help me>>>
Old Apr 5, 2006 | 05:06 AM
Pullig's Avatar
Default For all you nitrous and plug reading experts please help me>>>
Heres my question i have a 95 prelude with H23 no-vtec. Im spraying about a 50 shot with 0.036 nitrous and .024 fuel. My a/f are perfect like i want them good and rich. I do have it at stock timing.
I also am running the NGK 7 heat range which is 1 degree colder because stock is 6s. Well when i checked the plugs aftr a wot pull i noticed a slight pre-ignition sign on the porcelain.
Some very tiny black specks not too major and i noticed very slight amount of aluminum specs which would indicate pre-ignition. Well my question is that i really dont want to pull any timing i would like to keep the distributor at stock setting.
Could i get NGK 8 heat range and clear this up and gain more power than pulling some timing? Im wanting to run a 75 shot here soon just after i get my jets. What would be the corresponding fuel jet to use if im using an 0.040 jet for nitrous?
Cuz i would liek to keep the a/fs just like they are now . I was thinking of using a .028 ..
Old Apr 5, 2006 | 06:45 AM
SOHC_MShue's Avatar
Default Re: For all you nitrous and plug reading experts please help me>>> (Pullig)
pull timing
Old Apr 5, 2006 | 07:14 AM
slowhonduh93's Avatar
retard timing yo.... otherwise by using a colder plug than you have... its not going to help you with any of your problems... do it right or let your engine go boom....
Old Apr 17, 2006 | 08:23 AM
Phase Change Racing's Avatar
You need to take a couple degrees of timing out and a lot of fuel. .036/.024 is Wayyy too rich. You will cause a lot more harm than good running that rich.
XzIpK
May 13, 2007 07:16 PM
Pullig
Apr 5, 2006 10:54 AM
JDM H22
Jun 17, 2005 02:54 PM
grocerygetter
Aug 26, 2002 09:23 PM
twizt2
Dec 19, 2001 12:03 PM
