LOSS OF POWER?
i have a 99 honda civic ex coupe w/ a b18b1 swap in it. latly my car will bogg down when you press the gas pedal all the way down. and sometimes wont even start. i just had the timing belt and water pump replaced. timing is dead on. i just did a tune-up on it (cap,rotor,wires, and plugs) it helped a little but not much. my check engine light will come on when i am driving but noone can check the stored codes b/c i have a converter for the ecu to obd1 ls ecu. i am thinkin o2 sensor but i want to be sure before i get one. any help would be greatly appreciated.
thanks i will try that stuff today when i get chance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">chekc your ignition. pull ur spark plugs and see if they have oil on them.</TD></TR></TABLE>
yea i just replaced all of that stuff, cap rotor wire and plugs
ok well i checked the firing order it was right i even pulled of 2 of them and switched them and it was worse. my gas milage has gone to ****. amd air/fuel ratio guage is reading into the deep lean side. usually it runs right in the middle. i put new plugs in also, not too bad but also not too god either. i am thinkin maybe the o2 sensor???????
ok did the old paper clip trick, gave me 4 slow blinks and then 3 fast so i guess thats a code 43 on the code topic it says it a fuel supply system code? any ideas on what i do to change that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda head »</TD></TR><TR><TD CLASS="quote">could be a vacuum leak, but go to auto zone or something and get the codes checked just to be sure</TD></TR></TABLE>
i cant get the codes checked b/c it is converted to an obd1 ecu, and they can only read obd2, it wont make a connection with the ecu. i check around for vacum leaks didnt see anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK tommy »</TD></TR><TR><TD CLASS="quote">i had the same problem, it was the o2 sensor.</TD></TR></TABLE>
cool i will be putting one of these in today, hopefully it will fix my problem b/c my gas went from 350 miles per tank to like 250 per tank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kleanlscivic »</TD></TR><TR><TD CLASS="quote">
i cant get the codes checked b/c it is converted to an obd1 ecu, and they can only read obd2, it wont make a connection with the ecu. i check around for vacum leaks didnt see anything</TD></TR></TABLE>
thats just stupid... were do you live?... the autozone by my house has diagnostic tools for obd0,1,2... do you know anybody with a data logger?
South Carolina, the autozone here arent worth a ****, but i think i have it fugured out now i called honda with the code and they said it was the o2 sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kleanlscivic »</TD></TR><TR><TD CLASS="quote">South Carolina, the autozone here arent worth a ****, but i think i have it fugured out now i called honda with the code and they said it was the o2 sensor</TD></TR></TABLE>
awesome... thats good... man i cant believe those autozones dont have the obd0 and 1 plugs, man you should invest in a data logger... well, i need to get one too
yea i know, well hoepfully this 02 sensor will fix it b/c right now my **** sounds like a lawnmower
</TD></TR></TABLE>yea i know, well hoepfully this 02 sensor will fix it b/c right now my **** sounds like a lawnmower
it will be the one before the catalytic converter (this controls the a/f mixture.) on an obd2 car, the o2 after the cat is mostly to check the operation of the cat/emissions. if you're running obd1, then the one on the manifold or before the cat (whereever yours is located) is the one you want to swap out.
thanks man. i bought an o2 sensor off of one of my buddys well it is actually the one for the cat itself, do you think it would be alright if i cut an spliced the other connector onto it? using heat shrink and it and all that good stuff? i mean thats how the universal ones are. let me know guys
