Starter Wire
Ok, So I did a search ('94 Civic) and found that the wires coming from the Ignition switch going to the fuse box are supposed to be as follows:
White: +12V
Black/White: Starter
Black/Yellow: +12V Switched with Ignition
Yellow: Ignition II
White/Black: ACC
Ok, so I am wiring in a starter cut off relay with my alarm system. Problem is, there are only 3 wires coming from the Ig switch, Black/yellow, Yellow, and White/black. Soooo... what happened to the starter wire (Black/white)?!
I already spliced the alarm into the switched +12V (blk/yel), and I need to put the relay in line with the starter wire. Where, praytell, do I do this if there is no such wire?
White: +12V
Yellow: Ignition II
White/Black: ACC
b16_madman
12
Jul 28, 2004 05:39 PM
allmotorEG-SI
Audio / Security / Video
Jan 3, 2004 10:25 PM
