whats the best ecu to run with a d16y7 turbo ???
Old Apr 4, 2006 | 10:06 PM
superhatchbackbros's Avatar
Default whats the best ecu to run with a d16y7 turbo ???
im keeping it OBDO so far i got a d16y7 non vtec motor with aprox. 45 thos miles gonna run a 88-91 crx Si Dizzy . and my car origonally was a 89 DX hb 5spd . i was wondering what is the best ECU to get bc im running turbo ( t25 ) ~ and what is the best engine wire harness setup to get .
thanks
jason & jesse
Old Apr 4, 2006 | 11:46 PM
crxnj's Avatar
Default Re: whats the best ecu to run with a d16y7 turbo ??? (superhatchbackbros)
Turboedit chipped 90-91 pm6 or pr4 ecu..
For wire harness just keep the stock dx and convert it to mpfi..http://crf50.no-ip.com/fourthgenhatch/mpfi.html Or send it to http://rywire.com and have them do it for you..
Old Apr 5, 2006 | 09:20 AM
i can get a ebay chipped pr4 ecu from my buddy that is chipped for air fuel and high rpm? would that work. better then my stock pm6??
Old Apr 5, 2006 | 12:36 PM
crxnj's Avatar
Default Re: (superhatchbackbros)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superhatchbackbros &raquo;</TD></TR><TR><TD CLASS="quote">i can get a ebay chipped pr4 ecu from my buddy that is chipped for air fuel and high rpm? would that work. better then my stock pm6??</TD></TR></TABLE>
Not really..It has to be specifically tuned for your engine/turbo setup..
Old Apr 5, 2006 | 01:03 PM
Autoworks's Avatar
Definately not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
Not really..It has to be specifically tuned for your engine/turbo setup..</TD></TR></TABLE>
exactly, run a PM6 and tune it with turboedit
Old Dec 6, 2006 | 10:22 AM
MotoCARR's Avatar
Default Re: whats the best ecu to run with a d16y7 turbo ??? (mr.speaker)
Up for new info. I will be running the same motor and T25 turbo. Is there a place that I can get a breakdown of what I will need to connect my laptop to an ecu? I figure it will be USB or serial on the laptop side, but I don't see how the laptop would connect to the ECU to tune? I assume tuning looks something like this:
1. Connect laptop and drive the car and make necessary adjustments
2. Once done, burn the map to a chip
3. Place chip in ECU and disconnect laptop.(I assume the laptop doesn't have to stay in the car)
mreasyme
Dec 2, 2007 08:54 AM
em1_fox
Oct 13, 2007 10:49 AM
zenon8890
Nov 25, 2005 06:34 PM
phatcivic99
Nov 24, 2003 10:45 AM
Baggy Spandex
Oct 4, 2003 02:41 PM
