which ecu to use? ( mini me swap)
Old Apr 4, 2006 | 07:48 PM
Unreal98wrc's Avatar
Default which ecu to use? ( mini me swap)
ok heres my setup
98 civic dx
d16y7 block
94 d16z6 trans and head
warner ishi ihi rbh52 w/ .48 ar and custom top mount setup.
dsm450cc injectors
aem fpr and fuel rail
walbro 255hp lph
arp head studs
cometic metal ehad gasket
cp low comp pistons
eagle connecting rods
clevite bearings
+ tons of other goodies i just car not to mention cause its not needed
well i will be running vafc2 hack and im wondering about just controlling the vtec through the vtec controller or since i have a p72(99 obd2a gsr ecu) if i should swap com,puters and increase redline wile dumping enough fuel for a 1.8 liter. well since the vafc2 only haas adjustable fuel maps of +/- 50% will the p72 ecu add 2 much fuel with the injectors and fuel pump and will i not be able to controll it tot he poitn of being a daily driver. i should be pushing about 12-15 psi( most my turbo can handle till i upgrade the turbo setup soon. if any of yall know anything please help me out if none of this works then i might just go greddy emanage ultimate.
main question is should i justrunt he p32 ecu w/ vafc2 or swap to a p72 w/ vafc2? and if p72 will it be 2 much?
and no i am not swaping to and obd1 ecu unless i know for a fact i can pass emissions in illinois
Old Apr 4, 2006 | 08:30 PM
912's Avatar
912
Default Re: which ecu to use? (Unreal98wrc)
bro i have a 96 ex ecu willin to trade if you have a 92 95 dx dizzy for trade
foxdie
Nov 28, 2012 04:02 AM
NXAccordTO4B
Nov 18, 2003 07:30 PM
SoulSurfer
Mar 19, 2003 03:26 PM
CivicSoul
Oct 15, 2002 08:25 AM
