Fuel Gauge voltage
Old Apr 4, 2006 | 07:33 PM
Batoutahell's Avatar
Default Fuel Gauge voltage
My fuel gauge is stuck on E. I unclipped the connector at the sending unit, jumpered the wires, and the gauge does slowly rise. I take it the gauge is functioning.
Here's the problem: when I probe both wires with the ignition ON, I only get 6 volts. I think I should be reading battery voltage. I tested the ground wire, (G511) it's okay. I checked the #1 10A fuse, it's okay.
Is the only thing left to check the continuity of the yel/wh wire? I doubt the yel/wh wire has a break, because if there was a break in that wire, I don't think I'd be reading any voltage. I assume it's a problem that I'm only reading 6 volts. Any suggestions why I'm not reading battery voltage?
92integraVTECgsr
Feb 22, 2018 08:33 AM
91(si)hatchey
Jul 29, 2009 08:16 AM
Batoutahell
Apr 5, 2006 12:52 PM
Liquidgsr
Audio / Security / Video
Apr 15, 2005 10:12 PM
G2ILS
Jan 17, 2005 12:14 PM
