Which KOYO for '98 spec JDM ITR?
Old Apr 4, 2006 | 07:06 PM
powersteer's Avatar
Default Which KOYO for '98 spec JDM ITR?
Hi all,
I'm in the process of getting a new Koyo for my car, but i realised that Koyo has 2 models for DC2
R2028-- 94-01 Integra DC2 Denso
R1741-- 94-01 Integra DC2 Showa
Does anyone of you know which is meant for my '98 spec JDM ITR?
Can my stock or Mugen radiator cap fit into the Koyo?
Old Apr 4, 2006 | 07:19 PM
dc2r_j's Avatar
Default Re: Which KOYO for '98 spec JDM ITR? (powersteer)
I swear I just asked this within the last 30 days. Not to be rude, I forgot which one it is when I realized my money should go elsewhere, but did you search?
Old Apr 4, 2006 | 07:23 PM
dc2r_j's Avatar
Default Re: Which KOYO for '98 spec JDM ITR? (dc2r_j)
https://honda-tech.com/zerothread?id=1565367
there you go
Old Apr 5, 2006 | 04:44 AM
powersteer's Avatar
thanks for replying.
I found it alittle contradicting as someone in ur post said that Denso is the one, but in another post, the seller mentioned that Showa is for ITR, Denso is for GSR/LS?
Btw, does the stock radiator cap fits the Koyo?
Old Apr 5, 2006 | 04:46 AM
powersteer's Avatar
from here
https://honda-tech.com/zerothread?id=1036108
Old Apr 5, 2006 | 03:29 PM
Black R's Avatar
25 Year Member
Default Re: (powersteer)
ok, so which did you get and how is the fitment, etc?
Old Apr 5, 2006 | 08:51 PM
stumpyf4's Avatar
Default Re: (Black R)
If you want to use your original fans, only the Showa will fit. If you're using other fans, either Denso or Showa will work.
Old Apr 6, 2006 | 08:12 AM
powersteer's Avatar
Default Re: (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">If you want to use your original fans, only the Showa will fit. If you're using other fans, either Denso or Showa will work.</TD></TR></TABLE>
Great man! thanks .. thats really the answer I'm looking for. Koodos and Cheers man!
Old Apr 6, 2006 | 08:49 PM
WhoisDan's Avatar
So which one is bigger...Denso or Showa?
I was told that the Showa was for JDM ITR Front Ends.
kchungb17a
Oct 30, 2011 06:01 PM
level12
Dec 31, 2008 02:32 AM
LERRY
Nov 21, 2007 04:41 PM
integlspwr2k
Jan 14, 2005 11:11 PM
