Oxygen sensor???
Old Apr 4, 2006 | 06:58 PM
hatchish's Avatar
Default Oxygen sensor???
Ok i got a b16 in a 92 hatchback and I kept throwing CEL #1 so i got a new sensor but i got it for free and they said it was from a single cam well after a few days it went out and that was a brand new sensor. I got O2 problems when i got headers. Anyone have any input? Are dohc and sohc cam 02 different?
Old Apr 5, 2006 | 09:40 AM
hatchish's Avatar
bump
Old Apr 5, 2006 | 10:10 AM
Relic1's Avatar
the O2 sensor has to match the ECU not the engine.
Since you have a 92 I'm betting you have a chipped P28 or a P30. A SOHC four-wire O2 is fine.
if you keep having O2 issues like this it's time to check out your wiring. faulty connections or intermitent shorting will cause problems quickly.
Old Apr 5, 2006 | 10:50 AM
hatchish's Avatar
yeah i have a chipped pr4 its tuned by a friend/shop but it doesnt always throw the code mostly does it when i down shift.
Old Apr 5, 2006 | 02:25 PM
Relic1's Avatar
sounds like a connection problem to me.
Old Apr 8, 2006 | 06:28 PM
b16a2_v-tech's Avatar
69.212.15.27
Default Re: Oxygen sensor??? (hatchish)
i got the same problem with the header thing, i have a 2000 si...when i changed from stock to dc-sports 4-1headers my engine check light came on and still is on for liek months now. they said its my o2sensor tellin me i need a new one. everysince then i been gettin bad gas milage compared to stock headers.......
Old Apr 9, 2006 | 07:20 AM
Relic1's Avatar
your bad gas mileage is from the ECU being in limp home mode due to the O2 CEL, not from the header.
Removing an O2 sensor from one header and installing it into another can damage a weak O2 sensor. If you're positive your wiring is good, replace the sensor and you should be CEL free.
Old Apr 10, 2006 | 06:29 AM
hatchish's Avatar
yeah i think i need a b series o2 also my car is hesitating under 4000 rpm's it started doing this **** once the CEL has been around, other then that im gunna check my timing.
sde780
Dec 15, 2009 04:54 PM
skata89
Apr 3, 2008 12:26 PM
90_Si
Aug 17, 2007 11:31 PM
lxcivic
21
Jul 30, 2007 07:59 PM
2000Si_b16A2
15
Dec 17, 2005 06:13 PM
